Old 08-18-2015, 11:24 PM   #1
TCR
Drives: 2013 Toyota 86 GT
Alternatives to gauges?
Hey guys,
I'm looking for something to monitor oil temp, oil pressure and coolant temp and provide shift lights on track. I'd also like to be able to set alarms on each parameter if I exceed a set limit and reviewing a peak for each would be an advantage but not essential.
I'm currently using the Torque Pro App, but it can't monitor oil pressure, and I still don't have shift lights.
Rather than trying to find and install three separate gauges and a set of shift lights, I'm looking for something in one neat package. I'd also like to keep the OBD port clear to use a Solo DL data logger in the future.
The only thing I've found to date is this:
http://www.defi-shop.com/products/ad...summary_zdcsp/
Any other ideas?
TCR is offline   Reply With Quote
Old 08-18-2015, 11:46 PM   #2
There is no oil pressure gauge from the factory; you need an external sensor.
I think what youre looking for is a full dash replacement, like the Racepak IQ3, or an AIM MXL Pista.
With both systems, you wouldn't need the OBD2 port clear for a Solo DL, as the dashes *ARE* dataloggers as well, and do everything the Solo DL can.
Old 08-19-2015, 01:25 AM   #3
TCR
I was looking into the Race Technology Dash2 Pro, as it was a cheaper alternative to the ones you've mentioned, but it's still quite an expensive option. I started looking into this as a cheaper alternative, albeit a bit more fiddly.
The Defi product works independently, as it comes with the sensors required to monitor the parameters I mentioned. It just means I'd have both the Defi display and the Solo DL display to mount instead of the one larger dash.
Both products should only set me back about $1500 AUD compared to $2300 AUD for the RT Dash and sensors. I believe the MXL2 has replaced the MXL Pista and would cost about $2700 AUD including sensors.
Old 08-19-2015, 01:27 AM   #4
Filipino Royale
Got Rice?
Filipino Royale's Avatar
Drives: 37J BRZ-L
@CSG Mike what kind of external sensor? Im looking to buy the defi bf, i think it comes with a sensor.
Be a Leader, Be a Friend, Be at Service. -AɸΩ
Filipino Royale is offline   Reply With Quote
Old 08-19-2015, 01:27 AM   #5
Filipino Royale
Got Rice?
Drives: 37J BRZ-L
Old 08-19-2015, 01:48 AM   #6
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I had the Race Technology Dash2 Pro in my Minibusa. It will do every thing you want, but requires separate sensors for all inputs.
Lunatic is offline   Reply With Quote
Old 08-19-2015, 01:51 AM   #7
It has, but sometimes you can find it on clearance if someone has a unit they can't get rid of
Old 08-19-2015, 01:51 AM   #8
Oil pressure.
Old 08-19-2015, 02:25 AM   #9
Filipino Royale
Got Rice?
Drives: 37J BRZ-L
Oil pressure.
Ook, i thought you were saying about a different sensor, so the one from defi is okay, i just need an adaptor to fit the 1/8" NPT
Old 08-19-2015, 08:57 AM   #10
frssfo
frssfo's Avatar
Drives: 2015 FR-S
For il pressure, you can use the galley plug at the top of the block. It is easy to get to. You can install the sensor without draining the oil.
You'll need one of these: http://prosportgauges.com/subaru-oil-galley-plug.aspx
For oil pressure I used this gauge, which has an alarm if oil pressure dips below the pressure that you set: http://prosportgauges.com/amber-whit...ure-gauge.aspx
frssfo is offline   Reply With Quote
Old 08-19-2015, 08:08 PM   #11
Streetthrowback
Drives: 2015 brz
Aim makes great dashes
Streetthrowback is offline   Reply With Quote
Old 08-19-2015, 09:17 PM   #12
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I had their Boost gauge that I purchased when I had my Evo, it never really worked properly (still sitting somewhere in my garage) ..maybe it was just my luck
glamcem is offline   Reply With Quote
Old 08-22-2015, 09:19 AM   #13
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Yep. The MXL2 is a vastly superior unit, we've got customer cars using the Pista and the MXL2 is much easier to use.
GSpeed is offline   Reply With Quote
The Following User Says Thank You to GSpeed For This Useful Post:
CSG Mike (08-22-2015)
Cheaper Lip alternatives jdmblood Cosmetic Modification (Interior/Exterior/Lighting) 12 02-10-2015 11:44 PM
race gas and alternatives autobrz Engine, Exhaust, Transmission 3 11-22-2013 08:21 AM
86 Alternatives ??? H8R GTS AUSTRALIA 33 09-05-2012 12:59 AM
Alternatives to BRZ, sub $30k zygrene Other Vehicles & General Automotive Discussions 123 05-08-2012 12:23 AM
Nav alternatives? Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 33 04-13-2012 04:27 PM
