Old 08-18-2015, 02:32 AM   #1
zerox86
Drives: Toyota GT86 with Aerokit
experiences with ACT SB7-XTSS
Hi, I bought a 2,000 Miles used Clutch for a small price . Can anyone tell me his experiences with the ACT - SB7 XTSS . My concern is for mainly by the lighter flywheel and freer revving the engine . Includes Clutch Rattle expected in this kit?
zerox86 is offline   Reply With Quote
Old 08-21-2015, 03:20 AM   #2
zerox86
No one any Idea?
Old 08-21-2015, 04:13 PM   #3
raytrix
Drives: Series 10 FR-S
Lighten flywheel issues.
http://www.ft86club.com/forums/showp...78&postcount=6
raytrix is offline   Reply With Quote
Old 08-21-2015, 06:40 PM   #4
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
The bite is much more crisp while the engagement window is much smaller. The response is much better than stock.
You get less "creature comforts" with a slightly lighter flywheel. The car becomes much more raw with the Prolite flywheel and "chatter" is expected (as is with any lightweight flywheel). The Streetlite has plenty of meat to run just fine. Make sure to use brand new throwout and pilot bearings for your install.
CounterSpace Garage is offline   Reply With Quote
Old 08-21-2015, 09:32 PM   #5
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I don't personally have any issues with mine. Its a streetlight not prolight. Its a Disc not a puck. Its heavier but not QQ heavy my leg wants to fall off.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 08-25-2015, 09:57 AM   #6
zerox86
can i use a new OEM throwout and pilot bearings or the ACT are different?
My Problem is, i canīt buy any ACT Parts in Europe. I must order the Parts in the USA for a minimum of additional 50$ shipping coasts.
I donīt found any seller with cheap shipping prices.
Old 08-26-2015, 12:51 PM   #7
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Not sure where people get this "chatter" from we have 4 cars in house with the ACT set ups and all on the light flywheels with no chatter. Make no sense how people are getting that noise. Maybe a bad install on the TOB?
FT-86 SpeedFactory is offline   Reply With Quote
Old 08-26-2015, 12:55 PM   #8
fika84
fika84's Avatar
I also experience no chatter with just a LWFW on the stock clutch.
fika84 is offline   Reply With Quote
Old 08-26-2015, 01:40 PM   #9
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
What is your idle set to? I only got chatter with stock idle when the AC kicked on. I have since raised my idle to 900rpm and it's noisy (probably LWFW amplified by alum ds) but rarely chatters anymore.
industrial is offline   Reply With Quote
Old 08-26-2015, 02:25 PM   #10
Some chatter is expected and normal with lightweight flywheels.
ACT recently revised their flywheels, and the latest generation of flywheels have improved their NVH, as well as their driveability.
The revised prolite flywheels JUST arrived on the 18th, and we already have one in our BRZ. There is chatter when you are not on the clutch pedal, in neutral, idling. No other noise.
The revised streetlite is due at the end of Sept, and will have no chatter at all.
If you've driven a STi, the XDSS has approximately the same pedal weight, but without as large of a decreasing force as you hit the bottom of the clutch stroke. The CSG BRZ is now on a XDSS.
Old 08-26-2015, 02:35 PM   #11
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
My experience, I have the street lite flywheel(900 rpm idle) and I chatter when idling with AC on. The pedal effort is slightly increase but once used to it you won't be able to tell the difference. The clutch is more grabby of course when engaging but nothing drastic.
I'm having some issues with mine where first gear and other gears as well get a little harder to push in when the car has been driving for a while. Then again judging by others experiences I'd say I have a problem with my car. I also get a shaking, not always, when taking off in 1st gear or moving in 1st, meaning engaging moving and disengaging...
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 09-22-2015, 05:18 AM   #12
zerox86
Anyone knows the original thickness of the Clutch disc from this Kit? My Clutch disc is used and has Face-to-Face thickness from 8.2mm. Is it okay or must change before install?
act xtss clutch blown Engine, Exhaust, Transmission 0 10-22-2014 02:35 PM
Experiences with CPO? heisenbergbrz BRZ First-Gen (2012+) — General Topics 20 04-22-2014 09:44 AM
Experiences with plasti dip Chen Northwest 24 10-30-2013 12:18 AM
Good/Bad dealership experiences SubieNate Southern California 3 05-11-2013 11:59 AM
LA/OC Dealer Experiences? l0aded Southern California 0 02-10-2013 10:40 PM
