Old 08-17-2015, 01:51 PM   #1
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
Rocker panel damaged! :(
I was going 1km/h in a parking lot.. someone parked in front of me so my angle was very tight. I was parked at the end of the lot with a curb next to me.. highest curb i've ever seen.
Took the turn too tight and this happened.. any guestimates for how much this will cost to fix
I swear this is the sofest metal/steel i have ever touched!!!
RickyRacer is offline   Reply With Quote
Old 08-17-2015, 01:59 PM   #2
Pickleahoy
Drives: 10 Series #1617
TOTALED
Pickleahoy is offline   Reply With Quote
Old 08-17-2015, 01:59 PM   #3
Not gonna sugar coat it. That will cost you big! There is no easy/cheap way to fix that.
Light metals yes but anything short of 1/4 inch steel would have taken damage by the looks of that.
Just for reference this cost $1,200:
Old 08-17-2015, 02:01 PM   #4
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
so apparently the replacement rocker panel costs about $400 and takes 2 hours to install.. then add paint etc. according to subaru.
luckily on mine there is no crease it's just a huge dent. Can't believe that costed you 1200!!!
Old 08-17-2015, 02:10 PM   #5
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
they are saying if the damage also impacted the inner panel, that's another 200$ to replace
judging by the looks of it.. it most likely did
Old 08-17-2015, 02:26 PM   #6
ButeraFRS
Guest
Posts: n/a
Me personally I'd just bondo it and paint it
The Following User Says Thank You to For This Useful Post:
humfrz (08-17-2015)
Old 08-17-2015, 02:27 PM   #7
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
Ugh... body work...
I dented my rocker panel right in the front going off track into a gator strip...
Kuri is offline   Reply With Quote
Old 08-17-2015, 02:28 PM   #8
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
Originally Posted by vroom4 View Post
2 hours to install? I don't think they are looking at the right part....
it's the right-side rocker panel.. not sure how'd they confuse that
the repair estimate is better than i expected
Old 08-17-2015, 02:32 PM   #9
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
Its attached by welds.....how can it possibly only take 2 hours to remove and replace?
not sure, that's coming straight from the horses mouth.
They said 2 hours to install a new one or 4 hours to repair this one. plus paint
I'm leaning towards a repair but i'm worried about rusting inside.. he said there might be a little bit of damage on the inner rocker but nobody will see it.
what they will do is drill holes, pull it back out, then prime, paint it, etc. if i opt for the repair.
Old 08-17-2015, 02:33 PM   #10
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
Originally Posted by Kuri View Post
Ugh... body work...
do you have any pictures?
do you mind sharing how you chose to repair it?
Old 08-17-2015, 04:10 PM   #11
Fishbed77
Fishbed77's Avatar
Drives: 2013 FR-S 6MT Whiteout
I don't see how it could be installed in just 2 hours. Is it not a continuous panel with the rear quarter and door arch? Will have to be cut out and welded in, with all the associated filler and finish work.
Fishbed77 is offline   Reply With Quote
The Following User Says Thank You to Fishbed77 For This Useful Post:
Tcoat (08-17-2015)
Old 08-18-2015, 01:55 AM   #12
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Side skirts gogo!
Packofcrows is offline   Reply With Quote
Old 08-18-2015, 09:54 AM   #13
NOHOME
Drives: RAVEN
Few ways to approach this. Pull it with a stud gun, replace the entire panel (whole side of car!) or cut a repair section from the quarter panel.
I was not able to find a partial repair section for the sills that was not the full rear quarter of the car.
I would go at it with the stud gun. If they are quoting two hours, this is the way I expect they are going. Skill dependent, but possible to get very good results.
Regardless of what they do, realize that the anti-rust coatings are going to be gone from any place where they weld. ie behind each stud. Bodyshops operate on a "5 years is good enough" mentality, so they are not really concerned about this.
NOHOME is offline   Reply With Quote
Old 08-18-2015, 01:02 PM   #14
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
by looking at that pic, id write it around $800ish. 10hrs body, 4.5hrs paint. pulling the metal, finishing out the body work. removing the quarter glass, tail light. re-undercoating the rocker, then paint the rocker/blend quarter/sail panel (no break off point). then you can remove one of the rubber caps under the rocker and spray an amber rust proofing wax back inside the rocker since the oem will burn off on the backside when you use the stud gun/dent puller.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
Tcoat (08-18-2015)
Dented rocker panel daftpunk Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 49 08-15-2017 10:41 PM
Clipped my rocker panel area on a curb. Advice would be appreciated! PhysicalGraffiti Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 04-07-2017 08:45 PM
Deep rocker panel scrape Ryūkotsusei Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 03-29-2015 12:40 PM
Dented rear wheel side panel/rocker panel. Autocon Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 19 12-22-2014 11:18 PM
Light side skirt for Dented Rocker Panel cmitc004 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 07-10-2014 06:45 PM
