Old 08-17-2015, 01:20 AM   #1
ray7792
ray7792's Avatar
Drives: AT 2013 BRZ Limited
Sway Bar questions
Hi,
I just finished installing TRD lowering springs and had to cut the end links on the front due to rust, so at the moment I am running without a front sway bar. I haven't driven it hard yet so honestly not sure what to expect although given how soft the OEM one is I don't expect a huge difference...or and I wrong?
1) Buy OEM endlinks and be done with it?
2) Purchase TRD, whiteline, or perrin sway bar since I'll have to get under the car again either way?
3) Drive without a front sway bar, might be good for the snow anyhow =D
If I do get a stiffer front sway bar, how would that affect the rear? Is it dangerous/unpredictable enough that I should also change out the OEM rear bars as well?
I read that in order to get the full effectiveness of stiffer bars, endlinks need to be changed as well? How true is this?...given that an OEM pair would run about 50-60 bucks compared to whiteline 120+ just for endlinks, is it worth it?
I have done some reading but still unsure, if someone can drop some knowledge on me that would be nice.
Thank you for your time!
'13 BRZ (sold)
'17 STI
ray7792 is offline   Reply With Quote
Old 08-17-2015, 02:18 AM   #2
swarb
1. If money is an issue oem is cheap used.
2. Your money your call. Usually people change one thing at a time to see how the car changed. I would do it if you don't want to do the labor twice and buy twice if you know you are going to get a sway bar down the road.
3. Good if you like to drift. Bad if you can't drift.
I don't know how to answer the other questions.
Old 08-17-2015, 09:40 AM   #3
twag4
Drives: frs
If you aren't lowered more than one inch, stock links are fine. The links themselves do not affect the twist rate or force required to twist the bars. If the stock links cause your bars or the links themselves to contact something else on the car they aren't supposed to contact, buy adjustable links. As far as new bars, your call.
twag4 is offline   Reply With Quote
Old 08-17-2015, 10:23 AM   #4
wparsons
wparsons's Avatar
I have the stock end links, but if/when I buy new ones I'll be buying ones with a bolt/nut that goes through the link instead of a little balljoint like the stock ones. That way if a nut seizes on you just need to cut it off and replace the bolt/nut, instead of the whole link.
As for options for bars. Without a front bar the car will be very rear biased (oversteer). A stiffer front bar will make it more front biased (understeer). Personally I would stick with the stock bars unless you're trying to change the handling balance with a specific purpose.
flickr
Old 08-17-2015, 07:55 PM   #5
ray7792
ray7792's Avatar
Thanks for taking the time to answer people.
Yeah, guess I'll stay OEM, serves my purposes.
'13 BRZ (sold)
'17 STI
FS: Koni shocks, TRD sway bar & WRX sway bar scirocco78 Brakes, Suspension, Chassis 14 08-31-2015 06:47 AM
WTB: Rear sway end links or sway bar with endlinks JoeBoxer Want-To-Buy Requests 1 08-03-2015 01:20 PM
Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. FRSport.com Brakes, Suspension, Chassis 0 01-23-2015 12:38 PM
Wax Sealant Pad Questions / Care Questions l0aded Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 03-25-2014 11:19 AM
Ajdustable front sway bar link on a coilover questions Vten Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-06-2013 09:39 PM
