Old 08-16-2015, 08:35 PM   #1
MirthScout
Drives: Scion FR-S MT Hot Lava
Mistake installing LCA, need part
I need a replacement part but don't even know what it is called.
The front lower control arm and the lower arm support plate both slide onto the same bolt or threaded rod that sticks down under the front of the vehicle on each side. Is it a bolt or a threaded rod (cannot get to other end)? What is it called / what is the part number? How do you remove/replace it?
Was asked for a picture so I'll try to add it here:
... failed so here's a link.
MirthScout is offline   Reply With Quote
Old 08-16-2015, 09:52 PM   #2
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Take a picture. It would make it a lot easier to help you.
Intent > Content
Old 08-16-2015, 09:53 PM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
THIS!
Old 08-17-2015, 02:46 PM   #4
Nigelr32
Drives: '14 GT86 project, '13 GT86 DD
It is a stud that unscrews from the body using a 15mm ring spanner or deep socket. Once the arm is off you will see the 15mm Hex so you can undo it.
The threads are M14 x 1.5 both ends.
Nigelr32 is offline   Reply With Quote
The Following User Says Thank You to Nigelr32 For This Useful Post:
solidONE (08-17-2015)
Old 08-17-2015, 07:19 PM   #5
MirthScout
Thanks, Nigelr32. I got it out and it doesn't look bent. That's bad because that means the hole is bent.
Old 08-18-2015, 09:41 AM   #6
solidONE
solidONE's Avatar
Now we have established which piece of hardware you're referring to. What is the problem you're having with it?
Sounds like it doesn't line back up with the mounting holes on the LCA?
Intent > Content
Old 08-26-2015, 07:23 PM   #7
MirthScout
Basically the hole in the frame that that bolt screws into was bent. With it bent the lower arm support plate cannot be reinstalled. A large bar slipped over the bolt and application of force to bend back to verticle seems to have fixed it.
Then reassemble, correctly this time. The incorrect install was my fault and the correct way to install is obvious in hind sight. After market kits should come with instructions, no matter how obvious installation should be.
Just got it aligned again so all is well.
Old 08-26-2015, 09:26 PM   #8
solidONE
solidONE's Avatar
Glad you got it sorted out. What were you installing, if you dont mind me asking?
Intent > Content
Old 09-10-2015, 10:16 AM   #9
MirthScout
I installed adjustable front lower control arms from RacerX Fabrication. Very nice part. There are a selection of colors if you want to pay extra for anodizing. It goes under the car so that's just silly. I got orange.
Almost made a $15k mistake... Ghostface Scion FR-S / Toyota 86 GT86 General Forum 73 03-18-2015 08:21 PM
My mistake and trying to fix it.... ShowTime_DW Scion FR-S / Toyota 86 GT86 General Forum 5 04-14-2013 11:07 AM
Big mistake... BuBlake Issues | Warranty | Recalls / TSB 49 04-07-2013 03:01 PM
My First Mistake slizoth BRZ First-Gen (2012+) — General Topics 117 01-24-2013 04:19 PM
Big Mistake GoSharks Tracking / Autocross / HPDE / Drifting 40 11-03-2012 03:42 PM
