Old 08-14-2015, 06:25 PM   #1
Top-Secret
Drives: FRS monogram
Canadian's with Diode Dynamics Tails as turn module!!!
This only relates to any canadians that purchased Diode Dynamics Tails as Turn
Has anyone run into the issue with your signal lights not signaling while applying the brakes?
im not sure if this has been an issue since i bought the module or if it happened over time but currently will not signal while i have the brakes applied.
talked to Diode and they said it was only tested on USDM models so they are unsure about use on canadian vehicles. If this is not an ongoing issue for canadian vehicles i should be able to get a new one due to faulty unit instead of 'uncompatibilty' which is what they think could be the issue right now
so please chime in fellow canadians
Top-Secret is offline   Reply With Quote
Old 08-14-2015, 06:41 PM   #2
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Well the leds are not double filament bulbs so I would take it as it's either brake or signal. I'm pretty sure your fr-s is US spec as well. I wanted to do this mod also so can members with the tap turn confirm that it's either brake or signal and not both.
Old 08-14-2015, 07:06 PM   #3
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
No problems with mine yet and I've had it installed since last December
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 08-14-2015, 08:50 PM   #4
Joyride86
Joyride86's Avatar
Drives: 15 FR-S Firestorm MT
I don't think the Canadian models have different tail lights so it shouldn't make a difference. When you brake both tail lights should be on. If you signal while braking, only the one side will essentially flash (dim and bright). The other side will be full bright.
What is happening for you now? Are all of you signals not working. I couldnt tell from your post. If that's the case, you could have a faulty flasher module.
Diode Dynamics Tail as Turn, LEDs, HIDs | Yospeed Custom Plaque and Frame | Suntek Carbon Tint | Spyder Smoked Side Markers | GrimmSpeed License Plate Relocator and Hood Struts | Five:AD Spoiler | JDM Armrest | Beat-Sonic Backup Cam | Moddiction Anvil 2 | Invidia N2 |
Joyride86 is offline   Reply With Quote
Old 08-16-2015, 06:12 PM   #5
Top-Secret
Rear signal's are working, but when I brake they stop.as if I wasn't signalling at all even tho my front signal's are still flashing
Old 08-17-2015, 08:43 AM   #6
Lorico
Drives: 2015 FRS
Either you have an issue with your wiring or you messed up somewhere during your install.
Mine works perfect. Love this mod
Lorico is offline   Reply With Quote
Old 08-17-2015, 11:42 AM   #7
Top-Secret
I don't think it's possible to mess up the install
The Following User Says Thank You to Top-Secret For This Useful Post:
Xuningshen (08-20-2015)
Old 08-17-2015, 11:53 AM   #8
Bergen23
Drives: '15 Halo FR-S
Mine works fine
Bergen23 is offline   Reply With Quote
Old 08-19-2015, 05:52 PM   #9
Top-Secret
@Diode Dynamics what do you recommend i do?
canada, canadian, diode dynamics, tails, turn signal
Always-On™ Module for Subaru BRZ by Diode Dynamics JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 246 03-31-2025 01:02 AM
Issues with Diode Dynamics brake as turn signal + reverse light module SkAsphalt Cosmetic Modification (Interior/Exterior/Lighting) 12 12-21-2015 01:41 PM
(((SOLD))) FS: Diode Dynamics - Tail as Turn with Backup Module wrb Exterior Parts (Aero, Lighting, Etc.) 0 05-04-2015 07:13 PM
Diode dynamics turn signal bezel blackfireball5 Forced Induction 5 04-13-2014 04:33 AM
Diode Dynamics Switchback Turn Signals LED 2isballer Cosmetic Modification (Interior/Exterior/Lighting) 2 03-02-2014 02:46 PM
