Old 08-14-2015, 01:21 PM   #1
funwheeldrive
TOMS Relay Question
Hey guys, I just recently bought a set of USDM TOMS for my car. Will the included relay mean that the taillights work exactly like stock?
I remember hearing about aftermarket LED taillights having a delay with the turn signals, and I also remember hearing about a aftermarket relay that helps fix this problem.
Will I need anything else besides what was included with the TOMS box for them to work properly? I don't want to go through the trouble of installing them, just to have to do it all over again in a week. Thanks in advance.
Old 08-14-2015, 01:31 PM   #2
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
The fist blink will have a longer duration than the subsequent blinks.
AFAIK that's a norm type of flashing delay used in EU cars.
Other than that you're good to go
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
funwheeldrive (08-14-2015)
Old 08-14-2015, 02:32 PM   #3
funwheeldrive
That makes sense. Does that mean my blinker click inside the car will be out of sync with my turn signal lights?
Old 08-14-2015, 02:41 PM   #4
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Nope. It'll be in sync. Just the duration of both the cluster and outer lights for only the first blink are longer.
Old 08-15-2015, 01:27 AM   #5
Poodles
Drives: 2015 Series.Blue
I'd still get a tap-turn
Old 08-15-2015, 09:43 AM   #6
Jdogg88
Drives: Sapphire Blue ‘23
Nope, you should be good to go!
Jdogg88 is offline   Reply With Quote
Old 08-16-2015, 01:09 AM   #7
funwheeldrive
Thanks guys. Everything works great.
Old 10-02-2015, 03:40 PM   #8
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
I have TOMs with the hyperflash relay module installed. Will this also prevent the front turn signal bulbs from flashing too fast if I install LEDs? I plan on buying some LED replacements from DiodeDynamics for the front bulbs.
Reviving old thread as opposed to starting a new one since I used button!
MokSpeed is offline   Reply With Quote
Old 10-02-2015, 03:46 PM   #9
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Yes, you can use the same relay for other LED products
MokSpeed (10-02-2015)
Toms Side Skirts, Toms Shark Fin, Toms Rear Diffuser Toms Axel Back & MORE Jwong Exterior Parts (Aero, Lighting, Etc.) 16 09-25-2015 12:00 PM
Toms Taillight Relay mkivalex Cosmetic Modification (Interior/Exterior/Lighting) 6 04-06-2015 02:21 AM
FS: Taillights + Relay (BRZ OEM) - $70 iambmelt Exterior Parts (Aero, Lighting, Etc.) 2 10-03-2014 12:53 AM
HID Relay FRSure Cosmetic Modification (Interior/Exterior/Lighting) 14 03-13-2014 09:50 PM
HID Relay needed? corvino26 Cosmetic Modification (Interior/Exterior/Lighting) 12 01-04-2013 09:16 PM
