Old 08-11-2015, 04:14 PM   #1
dubaar
Drives: 2013 FR-S 6sp
Another Unichip not cooperating - p0172 engine code
Hey guys...
I KNOW this has been asked before... i've done extensive searches on it...
I'm getting extremely frustrated with my unichip. I have been getting the P0172 Code with the CEL and Traction light (as per normal "safe mode").
I have talked to Jack... who is very willing to chat and has been very responsive... but not overly helpful with trying to Troubleshoot.
He has advised me... As it seems that it has gone out to many of us that had similar problems... that it is caused by a "vacuum leak" in the Intake system, and he advised me to check to make sure all of the seals were done correctly around the pipes.
I have of course done this, and un-insitalled/reinstalled the unichip several times to make sure all of the connections were tight.
I still get the CEL with P0172
it usually takes a while to kick on the first time, then I reset with my code clearer, and it takes less time before it shows up again.
SO... i pose to you.... PLEASE WITHOUT TROLLING ABOUT UNICHIP... has anyone actually figured this out yet?
I have:
Cleaned the Maf
Checked all the electrical connections
checked the ground
confirmed that the selector is working
tried a large variety of maps (including all of the variations with "fuel out")
installed it several time with countless reflashes of the ecu.
checked all of the connections on my intake
I would PREFER to stick with it... a) because i know it WORKS... there is a NOTICABLE difference when it is running well before the CEL comes up (sometimes for several days), b) it is already $ and time spent, and c) i am warranteed until Aug 2017.... and I would prefer to use a pigy back to not void it.
So please... Anyone have any thoughts on what it may be, or what I have missed...
or honestly... if i should just say eff it... and get a proper tune. (because thats what i'm leaning towards)
Thanks
Quoth the Raven, "Nevermore."
dubaar is offline   Reply With Quote
Old 08-11-2015, 04:18 PM   #2
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
If you remove the unichip, do you still get the code?
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
dubaar (08-11-2015)
Old 08-11-2015, 04:29 PM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
^ That ^ The code is also for running too rich so I think ithas to do with the unichip. IMO you should get a ECU TEK tune I tuned my carwhen it had less than 1000km's lol. Warranty... aint nobody got time for that!!
Old 08-11-2015, 04:29 PM   #4
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
My experience was almost identical to yours. I'm sure my thread was one of the ones you read, if you searched here. I removed my Unichip some time last year and haven't had a P0172 code since.
My Unichip is for sale, BTW...
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
The Following User Says Thank You to jeffchap For This Useful Post:
dubaar (08-11-2015)
Old 08-11-2015, 07:38 PM   #5
phrosty
For the year I had a Unichip installed, I had no issues. If the issue goes away when you remove it, I wonder if you've got an incorrect tune loaded on it.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 08-11-2015, 08:51 PM   #6
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
honestly, it sounds to me like it's not worth the time and effort to me. sell the unichip if you can for ~200 (I don't know what the going rate is for them). buy a used OFT for around 400. one time flash that is easy to go back to stock and i'm guessing you won't have the issues. I know you said you are set on it but I wouldn't be interested in the constant hassle of something not working.
cdq85 is offline   Reply With Quote
Old 08-11-2015, 09:45 PM   #7
dubaar
Nope
Runs like a champ.
I even had it run through "under warranty" because it was throwing the code. I removed the chip... dealer couldn't replicate the conditions... so they "couldn't understand" why it would throw the code.
(didn't tell them about the unichip)
I honestly think.... Openflash is the way I want to go (legitimately) from what I have been reading... but I figured i would try giving it one more chance.
Old 08-11-2015, 09:49 PM   #8
dubaar
haha... it was.
Well good to know that you never found an answer.
I think my car just doesn't want to cooperate with it.
I thought it might be the same thing... because i've seen a lot of reviews like yours. so i tried every possible combination of maps that i could think of that might apply. and i did confirm that my 5 way switch was working because I loaded the "disable" map on it in various position and was able to select it...
but i just want it to work.. haha
Old 08-11-2015, 10:49 PM   #9
jeffchap
jeffchap's Avatar
One would hope that Jack would weigh in with a suggestion, but all I ever got from him was that there must be a vacuum leak. I think 7+ months without a code after removing the Unichip rules that out. Oh well, live and learn.
Old 08-12-2015, 12:40 AM   #10
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by dubaar View Post
Nope
Runs like a champ.
Then it sounds like either the Unichip or the harness is altering signals in such a way that the ECU deems implausible. You'll either have to get a revised tune file or go in another direction product-wise. If you have any questions about the OFT, let me know.
dubaar (08-12-2015)
Old 08-12-2015, 01:24 AM   #11
steve99
Hey guys...
I have:
Cleaned the Maf
checked the ground
Thanks
Run direct power and ground connections to unichip lots of issues cauesd by incorrect ot fluctuating voltages due bad ground or volts connections.
Flashing the ecu is a better way to go.
dubaar (08-12-2015)
Old 08-12-2015, 11:43 AM   #12
dubaar
Thanks Shiv... i suspect you'll probably have a question or two coming your way soon.
Thanks steve. That is what I was going to try next... i just really didn't want to try messing with the wiring too much... but may see if I can get that working...
unichip p0172 engine code bvelna Software Tuning 16 08-13-2016 08:45 AM
Unichip P0172 CEL and the FA20 Engine gdoyle05 Issues | Warranty | Recalls / TSB 3 09-16-2014 09:48 PM
Oiled filter and CEL code P0172 jeffchap Engine, Exhaust, Transmission 12 05-08-2014 05:24 AM
CEL code P0172 jonbonazza Issues | Warranty | Recalls / TSB 18 11-25-2013 08:35 PM
Engine Code: P0172 P117B *KID* Engine, Exhaust, Transmission 2 01-25-2013 04:23 PM
