Old 06-20-2012, 06:18 PM   #1
Rudiger
Drives: R32 GTR
Wheels that won't ruin the ride
Hi guys, I'm about to put a deposit on a white 86 and just had a few questions about wheel fitment. Basically I would like to change the wheels asap, however I want to make sure the wheels I buy aren't going to ruin the handling or ride. I learnt this lesson from a friend when he replaced his MX5 OEM wheels with 17inch rims, which completely ruined the handling of the car.
I actually have a set of CR Kai's in my garage, however I think they are probably too big (255/40/17). I pretty much don't want to change the feeling or handling of the car at all, so what wheel size would be best to go for?
Cheers :happy0180:
Rudiger is offline   Reply With Quote
Old 06-20-2012, 07:46 PM   #2
GenkiElite
GenkiElite's Avatar
Drives: 91 Corolla (dd) S14 (daily drifter)
Do you mean tires? You can put different width and profile tires on a rim. The rim height and width play a factor as well. Can you clarify what you have exactly?
GenkiElite is offline   Reply With Quote
Old 06-20-2012, 07:54 PM   #3
Rudiger
Drives: R32 GTR
Sorry if I wasn't clear, the tyres on the Works are 255/40/17 on all four wheels. I can't remember the size of the rim though, I think they are 17 x 9 (or 10?) I will have to double check, but I would've thought they would be too big regardless. They are also off my GTR, so fitment might be an issue too.
And to your answer your question I guess I'm asking what is the best wheel & tyre size combo to ensure the ride isn't affected. Thanks!
Old 06-20-2012, 11:16 PM   #4
GenkiElite
GenkiElite's Avatar
I'm thinking a 17x9 with 225/40/17 all the way around would be about perfect. I don't know anything about offset though.
Old 06-20-2012, 11:34 PM   #5
speed3
Walkin' on sunshine
speed3's Avatar
Drives: Ford BA MKII XR6 ute
If you wanted to go with 225 tyres wouldn't a 7.5" or 8" rim be better?
Gutsy question. You're a shark. Sharks are winners, and they don't look back because they have no necks. Necks are for sheep.
speed3 is offline   Reply With Quote
Old 06-20-2012, 11:37 PM   #6
RavSpec
Drives: Rx7
if it's for a GTR, u can't use it on BRZ. 5x100 bolt pattern !
For non-drop, OEM fits , I say go with 17x8 all around with 235/40 tires.
RavSpec is offline   Reply With Quote
Old 06-20-2012, 11:58 PM   #7
Rudiger
Drives: R32 GTR
Yeah I wasn't sure about the stud pattern What do you mean by non-drop?
Old 06-21-2012, 12:27 AM   #8
speed3
Walkin' on sunshine
speed3's Avatar
Standard ride height
Old 06-21-2012, 03:24 AM   #9
nix
nix's Avatar
Drives: AVO BRZ
17s or even 16s are the best size if you are concerned with ride but I think 18s are a nice compromise, and won't ruin ride.
Id suggest something like 18x8+40 with a 5-8mm rear spacer and 235/40/18
For a spacer free perfect fit you really need staggered wheel sizes front and back because there is extra space to fill at the back. Something like 18x8+38 and 18x9+38 or if you wanted the same rim/tyre size, 18x8+38 and 18x8+30.
nix is offline   Reply With Quote
Old 06-21-2012, 03:40 AM   #10
nix
nix's Avatar
Drives: AVO BRZ
For a stock replacement without lowering and not staggering wheel sizes:
17x8 (+36 to +42 offset) with either 225 or 235 tyres depending on your brand choice and available stock.
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 03:07 PM
Toyota GT86 First Ride KryptonZone FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 04-18-2012 05:47 AM
Will FI Ruin the Balance of FRS/BRZ? ZmZMWagon Other Vehicles & General Automotive Discussions 8 04-12-2012 11:19 PM
Just got to ride in a BRZ! (TD soon) Draco-REX BRZ First-Gen (2012+) — General Topics 49 03-30-2012 01:19 PM
Why govt ruin everything 1660 Off-Topic Lounge [WARNING: NO POLITICS] 11 12-27-2009 03:52 PM
