Drives: brz
sti steering rack bolts and bushings
I can not get the stock steering rack bushings out. Anybody have good ideas? I saw somebody use a C clamp but I do not that have. I am also trying to do the sti longer bolts and those I could not even get in. It feels like they want to cross thread, and so I put the stock ones back in. Anybody have a hard time with these as well?
Drives: Evo X FE/FRS 10 Series
Cusco makes a tool to remove those. I used it when I did my STI steering rack bolts/bushings. Made the job so much easier.
Happy 86 day! Part# 965 935 SST http://www.cusco.co.jp/en/parts_prod...lease_ava.html |
Drives: '23 BRZ Limited
And you can make a tool exactly like that for like $10 in parts from Lowe's/Home Depot.
Drives: 2014 BRZ - 2004 GLI
1.5" galvanized pipe nipple and a clamp will do it.
Drives: brz
okay that will cover the bushings, but any idea why the bolts wont go in? I dont want to tripe anything
Drives: 86 GTS
I put my STI bolts in at the same time as my Whiteline bushings. A little bit of "stiction" going in, but I made sure I cleaned the far end of the bolt holes (at the front end of the subframe holes) and it was fine - start by hand until I was sure it was on the thread then handtools till tight.
Drives: 2015 Subaru Brz Limited
Do yall have the part number to the nut@ & bolts to do this mod? I called the dealer they had no clue what I was talking about.
#8 | |
Drives: 2014 Ultramarine FR-S
North American dealers won't have them since it's a JDM BRZ tS part. You can order them from Japan Parts: Bushings: https://www.japanparts.com/parts/detail/?id=43136 Bolts, nuts & washers: https://www.japanparts.com/parts/detail/?id=47821 |
| 100% Solid Press Fit Steering Rack Bushings | Carolina Dyno | Brakes, Suspension, Chassis | 9 | 04-17-2015 04:44 PM |
| Steering Rack Lockdown/Bushings | Apex_BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 08-18-2014 01:01 PM |
| TiC steering rack bushings review | mokinbird87 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 07-21-2014 12:43 PM |
| Solid Steering Rack Bushings (Press Fit) | Carolina Dyno | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 12-03-2013 12:13 AM |
| GROUP BUY - TiC BRZ/FR-S steering rack bushings | Turn in Concepts | Groupbuys | 186 | 03-19-2013 08:04 AM |
