Old 08-05-2015, 11:22 PM   #1
oh96s
oh96s's Avatar
FR-S NEW WHEELS!
Hey guys! I finally got rid of my prius tires and the OEM wheels on my FR-S! Im super happy on how these XXR 527's came out! These are 18x8.75 +35! These are wrapped in some 215/40's! Minimal stretch but i love it! However, im starting to wish i would've done +20 in the rear since i plan on lowering the car 2 inches. The rear is a couple centimeters from flush. When i lower it, will i need to add spacers in order to have it perfectly flush? I know the front will be perfect since there is a bit of poke right now, but the back is what im worried about. I was thinking of maybe throwing some 15mm spacers in the rear. Let me know what you guys think!
oh96s is offline   Reply With Quote
Old 08-05-2015, 11:33 PM   #2
swarb
Everyone's definition of flush is different.
Lower first, then spacers after. 5mm should get you most of the way there. 15mm requires bolt on spacers or extended studs.
Old 08-06-2015, 12:03 AM   #3
oh96s
oh96s's Avatar
How bad are bolt on spacers?
Old 08-06-2015, 12:18 AM   #4
swarb
I personally am fine with them. The "correct" way is buying the right sized wheels or buy extended studs and add slip on spacers.
Many people don't like them because of bolts on top of bolts with thin nuts, makes more failure points, and people usually cheap out and buy the cheapest possible(they are not cheap). You might even be better off just buying another pair at +20. Read up on it and find out if they are safe for you.
Old 08-06-2015, 02:27 AM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Minimal stretch?
215" on a 8.75" wide wheel is a pretty bad stretch.
-alex
Old 08-06-2015, 07:45 AM   #6
pinski
Stole my avy from zGrinch
pinski's Avatar
Drives: 2015 Audi S3
Originally Posted by mav1178 View Post
Minimal stretch?
-alex
That's what I'm thinking too. I run 235 on my 8.5" fronts.
OP - just think of the meats you could get on there. You could easily run 245s and it would give your car such an aggressive look. The only concern you may have then would be the fronts grabbing the fender liner at full lock.
2015 Audi /S3 | Panther Black | DSG
Gone...2014 BRZ, 2010 Lexus IS F-Sport, 2006 Mazda MX5, 1997 Mustang GT
pinski is offline   Reply With Quote
Old 08-06-2015, 08:51 AM   #7
SlammedSilly
Drives: 2015 Ultramarine FR-S
i used to run 235/45's on a 16x10... that was minimal to me, haha
SlammedSilly is offline   Reply With Quote
Old 08-06-2015, 09:28 AM   #8
adamg
Drives: brz
Minimal stretch?
-alex
i run a 215 on a 10" wide wheel, thats a bad stretch. stop putting false information in peoples heads 215 on a 8.75 is completely fine
adamg is offline   Reply With Quote
Old 08-06-2015, 11:34 AM   #9
mav1178
mav1178's Avatar
"false information"? so what exactly is safe since I am giving out "false information"?
Old 08-06-2015, 11:39 AM   #10
STV3
Señor Member
STV3's Avatar
Sighhh....
STV3 is offline   Reply With Quote
Old 08-06-2015, 01:13 PM   #11
godzuki
godzuki's Avatar
Drives: frs
Like swarb said, lower first worry about spacers later. Liking the wheels with the whiteout combo!
godzuki is offline   Reply With Quote
Old 08-06-2015, 01:48 PM   #12
oh96s
oh96s's Avatar
I actually agree with him. If you look at the wheel, there's hardly any stretch. I could run 18x10's on 215's. That's considered stretched.
Old 08-06-2015, 02:35 PM   #13
SoCalArgento
Drives: 2014 Argento FRS
OP- I'm liking the whiteout/gold combo as well 👍
Not to go off topic but does anyone have the actual weight of these ( XXR 527 18x8.75 +35)? I read of their site that they are estimated at approx. 23lbs?
Which makes me wonder if the XXR 550 in the same specs are the same weight even though they have more spokes.
SoCalArgento is offline   Reply With Quote
Old 08-06-2015, 03:55 PM   #14
adamg
Drives: brz
