Old 08-04-2015, 11:28 PM   #1
JuicyFruits
Drives: 2013 serie 10
Cold air intake question
Hi,
Not sure if I should post in this particular sub-forum...
Anyways. I have been talking about getting a cold air intake installed for a while. A co-worker/friend overheard me at work, and approached me a few days ago. He told me he had one installed on his previous car. When he sold the car he put back the stock intake, so he had all the parts needed laying at home. He offered me to come by his house and we could try to install it, free of charge.
It sounded like a good idea so I said yes. The guy is no expert but I figured a cold air intake was something simple and easy to install. We spent an hour or two cutting and drilling his parts to make it fit under my hood. We managed to do a good job, and now everything is snug and secure.
But now its been a few days and I'm wondering.. is there a risk I could be running "lean" with this setup? The MAF sensor was correctly installed (there's not check engine light) in the new intake. But I read that a change in diameter could "mess up" the sensor and give false readings. The diameter of the new intake is slightly larger ( ~0.5 - 1 cm).
I just wanted to save a few bucks but I dont want to do any damage to my engine. I'm no expert (obviously), thats why I'm asking for your opinions.
Thanks!
JuicyFruits is offline   Reply With Quote
Old 08-05-2015, 12:37 AM   #2
humfrz
Hi @JuicyFruits and welcome to .... The Forum .......
I'm no expert on CIAs for this car, but, from what I understand the basic OEM system is pretty darn good. However, I did drop in a K&N filter figuring it would be free-er flowing. I reckon it is ..... cause it "sounds" faster .....
Now about that bastardized system you congured up ..... it may be just fine, then again it may be messing with the engine.
If I were you, I would yank it off, reinstall the OEM air box and slip in a free-er flowing filter ........ and call it a "mod" ......
humfrz
The Following 3 Users Say Thank You to humfrz For This Useful Post:
kodyo (08-05-2015), raven1231 (08-05-2015), stevesnj (08-05-2015)
Old 08-05-2015, 08:45 AM   #3
ZeroTo86
ZeroTo86's Avatar
Drives: '13 FR-S Turbo (Greddy T620z)
Your stocks probably performed better than what you have on now. I would def put it back and like @humgrz said, put a drop-in and call it a day.
ZeroTo86 is offline   Reply With Quote
Old 08-05-2015, 09:03 AM   #4
raven1231
Highly doubt the new intake is causing any harm, also doubt it's gaining you any power, more likely producing less than stock.
Old 08-05-2015, 10:00 AM   #5
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
The stock intake is already pulling in cold air. An aftermarket intake is not necessary and usually counterproductive.
Yes, a change in tube diameter requires changing MAF scaling.
No, you probably aren't running lean, that will be corrected by fuel trims in closed loop. That's what the o2 sensor is for. If you log data, you will notice that the short-term and long-term fuel trims probably changed when you put the intake in.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following 2 Users Say Thank You to Spartarus For This Useful Post:
humfrz (08-05-2015), stevesnj (08-05-2015)
Old 08-05-2015, 10:29 AM   #6
stevesnj
stevesnj's Avatar
You could see a slight dip in MPG too. The intake was designed for the air tube that is on it.
My 2016 Build thread
Old 08-05-2015, 10:52 AM   #7
austinbrz
austinbrz's Avatar
Drives: 2015 BRZ Limited (Crystal Black)
I look at it like this....Cosworth spent a lot of R&D $'s on engineering a complete package for the platform and decided that the best option for improving air intake to the system was a high flow drop in air filter. If they had included a full CAI in any one of the stages it would have been able to sell on it's own and they would have made money on it, instead they are making a strong and ethical statement that there is no power benefit with with a non-stock CAI.
austinbrz is offline   Reply With Quote
The Following 4 Users Say Thank You to austinbrz For This Useful Post:
humfrz (08-05-2015), kch (08-05-2015), stevesnj (08-05-2015), Tcoat (08-05-2015)
Old 08-05-2015, 10:55 AM   #8
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by JuicyFruits View Post
Hi,
Thanks!
Go back to stock. The larger diameter will make you go lean when in Open Loop.
Old 08-05-2015, 11:45 AM   #9
mikool
mikool's Avatar
Drives: 14' Firestorm FR-S
If you needed to drill and cut, then we can assume this wasn't designed for your car. With that in mind, first question is: Is it a true CAI? If not then it will most likely be worse than your stock. Post a pic, it might help form better opinions from people.
mikool is offline   Reply With Quote
Old 08-05-2015, 12:18 PM   #10
Teseo
Drives: frs
The Following User Says Thank You to Teseo For This Useful Post:
Old 08-05-2015, 12:24 PM   #11
raven1231
It was designed by him for his car man. It's a rare one off CAI.
Old 08-05-2015, 01:35 PM   #12
Spartarus
...Just add nauseum
Spartarus's Avatar
Originally Posted by Draco-REX View Post
... The larger diameter will make you go lean when in Open Loop.
NO.
Long Term Fuel Trim is applied in open loop calculation. After the intake is installed, once the LTFT is stabilized, it will NOT run lean in open loop.
-Spartarus
Old 08-05-2015, 04:35 PM   #13
JuicyFruits
Thanks guys.
I havent noticed any change in performance so far. That wasnt my goal in the first place. I wanted a different sound mostly.
Still i'll probly go back to stock once the novelty wears off. Just wanted to be sure that a few weeks \ months wont damage anything.
Thanks!
Old 09-01-2015, 05:21 PM   #14
JuicyFruits
UPDATE!
After roughly one month, I have enjoyed the following ;
-Better MPG
-Deep, satisfying sound reminiscent of a V8 engine
-Gains of 30 HP
Alas, the car also developed a tendency to stall at idle. This was mildly annoying so I put the stock intake back in.
Guess I need to work on my design :P
best cai evar, squadrogue returns
WTB Cold Air Intake GotBRZ1691 Want-To-Buy Requests 3 05-05-2014 08:09 PM
FS: TRD Cold Air Intake normancw Canada Classifieds 3 04-04-2014 02:12 AM
Cold air intake question bhbnuckle Engine, Exhaust, Transmission 7 03-08-2014 11:11 AM
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 01:43 AM
GI/FS: AMR Cold Air Intake Kuzuri Engine, Exhaust, Bolt-Ons 5 08-19-2013 09:58 PM
