Drives: 2013 Subaru BRZ Limited (Black)
Just got back from alignment. Any thoughts?
Morning All,
Just got back from getting My 2013 BRZ aligned. I've recently lowered the car 1" on Hotchkis springs (easy install) and wanted to be sure alignment was in spec. I went in requesting the following (taped a piece of paper to the steering wheel): Front: as much even negative camber as possible from lower camber bolt and upper crash bolt, 0deg toe. Rear: -1/16 total toe-in Here is the final alignment spec: ![]() They mentioned that things were already close to spec. It is a shop I trust. Here are my questions: 1. I still have a bit less front camber than rear. Not currently tracking the car. Should I really invest $$$ into correcting the rear camber with the front getting pretty close? Will I really notice that 0.5deg difference between front and rear camber on the passenger side? 2. They didn't set my rear toe-in to -1/16 as requested. I presume the rear toe is for tracking straight at high speed. Is it worth going back into the shop and requesting them to get it right? Would I really notice a difference? Thanks all! |
Drives: 2014 Toyota GT86
Picture too small , can't see anything ...
Hmm.. It is showing up fairly large for me. Try this link:
http://s9.postimg.org/l8k8httf3/DOC002_Page_1.jpg |
Drives: 2013 Firestorm FRS
I wouldn't bother with the rear camber, unless it really bothers you.
I WOULD be bothered about the toe, since you taped a thing in the car asking for specific numbers and they just did whatever they wanted. |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Thay front toe is pretty wonky. Next time make sure you specify 0 toe each wheel not 0 total toe. I would take it back in personally
Drives: Supra, 2014 BRZ
Take it back
Toe should match from side to side both front and rear. |
Time Traveller
Yeah the camber is ok, but that toe is not cool. Zero out the fronts and a little negative in the rear if it's a DD.
Thanks fellas -- I'm calling back and will send it back in a few. I should be looking for 0 toe at each wheel in front, and -1/16 total toe in for the rear (-1/32 each side)
| The Following User Says Thank You to ajcarson11 For This Useful Post: | DAEMANO (08-03-2015) |
Seems like they are not a performance shop, what they've done is a better alignment than many cars will ever see, but for a performance application it is not acceptable imo.
Since you're not tracking it and I also assume not autocrossing it that alignment is probably good for DD purposes. If you were driving hard and were a finely tuned instrument of driving prowess you would notice some inconsistency in left to right turns due to the toe and camber, but the average sports car owner probably wouldn't even notice. Given your scenario, I'd just let it ride until you start doing the track and autocross deal and find a good local performance shop. Whether or not you do the modifications to the rear is up to you, I am holding off on it (same differential of 0.4 degrees) because I am not a good enough driver to hone in on the difference but will likely do it this winter. |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | ajcarson11 (08-03-2015), Tcoat (08-04-2015) |
#10 |
Strat61 you've probably got a good point.... I do plan to do some autocrossing down the road, but if i'm going to do that then i would be doing LCAs to correct front-to-rear camber anyway. So perhaps I will leave it until I start doing something more intense with this car.
#11 |
Drives: 2014 BRZ Limited SWP
My alignment is broken too
![]() But yeah, I would see if they can fix your toe >< Last edited by Kuri; 08-03-2015 at 04:36 PM. |
#12 |
Why does the date on that say 6/23/2003 7:55 PM?
#13 |
#14 |
i'm sorry, what?
Drives: Canada
that's a horrible alignment job
1. the front toe is in on one wheel and out on the other wheel. This means when your steering wheel is centered your wheels are / - / , this means to drive straight you'll have to move your steering wheel! 2. same for the rear toe, one wheel is in, the other is out, but since you cant steer your rear wheels the car will always drive itself a little to side. absolutely horrible
| Our Back to Back Savings Continue with our 2015 Memorial Day Sale! | FRSport.com | Announcements, Contests, Giveaways | 0 | 05-22-2015 08:10 PM |
| DIY alignment - quick way to set alignment while new suspension settles? | 1Cor10:23 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 12-11-2014 09:53 PM |
| Axle back exhaust feed back requested | Gruppe-s | Engine, Exhaust, Transmission | 10 | 12-10-2014 07:56 PM |
| Possible trade? Nameless axle-back for Perrin Resonated Cat-back | GTB/ZR-1 | Engine, Exhaust, Bolt-Ons | 0 | 03-26-2013 01:51 PM |
| Drove the 86GT and NC miata back to back on GT5 | Hanzo | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 39 | 01-07-2012 12:56 PM |
