Old 08-03-2015, 12:02 AM   #1
J_B_2
Drives: whiteout 2014 Scion FR-S
Turn signals running lights
Hello all, about three months ago I installed switchback led turn signals that I purchased from Diode Dynamics. My right led bulb burned out prematurely , so I reinstalled the factory halogen bulbs. They work as turn signals, but neither bulb stays on continuously when I turn on my lights or low beams as they did before installing the LEDs. Does anyone know what may be causing this?
Thanks
J_B_2 is offline   Reply With Quote
Old 08-03-2015, 07:51 AM   #2
SoCalArgento
Drives: 2014 Argento FRS
Did you only reinstall the right side with a halogen bulb? Meaning you're running led on driver side and halogen on passenger?
SoCalArgento is offline   Reply With Quote
Old 08-03-2015, 08:39 AM   #3
J_B_2
No, I reinstalled the halogen bulbs on both sides.
Old 08-03-2015, 12:07 PM   #4
Jrryjms07
Jrryjms07's Avatar
Drives: 2013 Firestorm
Replace the flasher module?
Jrryjms07 is offline   Reply With Quote
Old 08-03-2015, 02:23 PM   #5
J_B_2
I replaced my flasher module to fix hyper link when I rewired my tail lights to use the brake lights as turn signals, which was long before I installed the front led signals. So I currently have that same module installed. I also have the winjet headlights with the led running lights. Would that override the turn signals?
any FR-Ss running yellow/gold turn signals? BlueDubbinTDI Cosmetic Modification (Interior/Exterior/Lighting) 12 12-17-2013 11:02 AM
DIY JWMotoring LED turn signals sirhc DIY (Do-It-Yourself) Guides 54 03-16-2013 03:22 PM
Custom turn signals? benlevy3 Cosmetic Modification (Interior/Exterior/Lighting) 2 11-01-2012 03:23 PM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-11-2012 11:23 PM
