Old 07-29-2015, 04:26 PM   #1
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Exclamation Lop sided rear camber.
I've noticed that many 86 owners complain of the cross camber difference of up to -.5 degrees in the rear suspension, including my own MY13 model. I'd like to see if this is an issue with only some build dates involved or if this happens randomly.
Here are my rear camber specs and build date:
2013 FRS build date: 1/13
Left Rear: -1.0 Right Rear: -1.4
I've seen at least 3 to 4 other MY13 FRS with the exact same rear camber specs with build dates close to mine.
Thank you for you participation.
Intent > Content
Old 07-29-2015, 05:07 PM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Are you on stock suspension?
N1rve
Old 07-29-2015, 05:11 PM   #3
solidONE
solidONE's Avatar
Not any more, but that was the rear camber spec when it was still using factory coil over dampers and arms.
Intent > Content
Old 07-29-2015, 05:23 PM   #4
strat61caster
strat61caster's Avatar
Eh, adding the data point, minor issue imo if you actually care you're going to upgrade it to be adjustable in short order.
When I last measured it was -1.0 degree Left Rear, -1.4 degree Right Rear, OEM suspension everything back there, only toe adjusted. I'll go dig up my first alignment I believe it may have had different measurements and post it up if they are different.
ineedyourdiddly
solidONE (07-29-2015)
Old 07-29-2015, 06:21 PM   #5
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
sure it'll probably be off on one side or the other, but for 99.9% of users on here it wont be an issue.
Don't let it bother you lol.
Old 07-29-2015, 07:04 PM   #6
solidONE
solidONE's Avatar
This is true, but for those setting up their cars to compete where rear camber adjustment pieces are either prohibited or cost them points this will be an issue. I'm actually more curious than worried since I don't use factory suspension anymore. Though, it WAS an issue for me.
How about submitting your factory camber specs?
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
strat61caster (07-29-2015)
Old 07-29-2015, 07:27 PM   #7
strat61caster
My fronts were bang on, -0.3 degrees even from the factory.
I'm starting to think my car was defective with that level of camber now that I've got actual camber in the car.
ineedyourdiddly
Old 07-29-2015, 09:36 PM   #8
TheVoiceOfReason
TheVoiceOfReason's Avatar
Drives: BRZ Limited
I've heard that it's because the rear sub-frame isn't perfectly centered. A really good alignment tech can play with the rear sub-frame and get them even. Probably easier just to get lca's.
TheVoiceOfReason is offline   Reply With Quote
The Following User Says Thank You to TheVoiceOfReason For This Useful Post:
Old 07-29-2015, 10:09 PM   #9
solidONE
solidONE's Avatar
Huge difference the turn-in and front grip. Mine were something like fr-0 rr-.05 or somethign stupid like that. Camber bolts were the very first thing I installed to address this.
This is what I've heard as well. You'd better be good friends with the tech, otherwise good luck convincing one to do that for you.
Intent > Content
Double sided tape wootwoot Cosmetic Modification (Interior/Exterior/Lighting) 12 07-14-2015 09:58 PM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
Does toe affect camber in the rear? More camber on one side after alignment shattered_memory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-30-2014 09:37 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
