Old 07-29-2015, 12:54 PM   #1
fridayfrs
Drives: Frs
Seat upholstery hook?
I'm starting a seat cover install on my FRS. They are Clazzio. The book shows unhooking a loop which I think I can feel the elastic band but I can't quite figure out how to unhook it.
I can't see a thing so going by feel. The YouTube video is no help on this step and after searching I didn't see this addressed.
Any suggestions appreciated.
Thx!
fridayfrs is offline   Reply With Quote
The Following User Says Thank You to fridayfrs For This Useful Post:
NWFRS (07-29-2015)
Old 07-29-2015, 01:25 PM   #2
DIM
You can also remove the seat, it's just 4 bolts. It might be easier putting on when the seat is out of the car.
DIM is offline   Reply With Quote
The Following 2 Users Say Thank You to DIM For This Useful Post:
fridayfrs (07-29-2015), NWFRS (07-29-2015)
Old 07-29-2015, 01:37 PM   #3
fridayfrs
Drives: Frs
This is my plan b. I'd rather not if I can achieve the same results. One of those if it wasn't for bad luck I'd have none at all.
Old 07-29-2015, 02:43 PM   #4
8R6
8R6's Avatar
Drives: FRS
IF you do remove the seat (which is super easy), just remember to use an E10 Torx socket for the bolt. and even then becareful not to strip the torx bolt - they're super soft
8R6 is offline   Reply With Quote
The Following 2 Users Say Thank You to 8R6 For This Useful Post:
Old 07-29-2015, 10:37 PM   #5
fridayfrs
Drives: Frs
Finally fumbled enough to get it off. Basically I followed the elastic band to where it curved and pushed to the front of the car to get it to release. There appeared to be too hooks or catch points. Front seats are on. Going go try the backseat a when it isn't 90* in the garage. Thx all!
Upholstery Work in FWB Area? kmbkk Southeast 1 09-08-2015 12:25 PM
Steering Wheel Upholstery Canehda CANADA 8 04-09-2014 05:08 PM
Has anyone installed brown leather upholstery? NWFRS Cosmetic Modification (Interior/Exterior/Lighting) 10 10-09-2013 12:39 PM
Anyone change the upholstery yet? dro Scion FR-S / Toyota 86 GT86 General Forum 3 05-24-2013 04:58 PM
OEM Upholstery ExWhyZer0 Cosmetic Modification (Interior/Exterior/Lighting) 9 12-25-2012 01:21 PM
