Old 07-24-2015, 08:22 PM   #1
TurboBRZ
TurboBRZ's Avatar
Drives: 2013 BRZ Limited
Traction - Where is it?
It's been a while since I've had a turbo car, and my last one was a 240SX with a SR20DET in it. I used to drag them at the strip all the time (and drift em), and one thing I hardly recall having an issue with was traction. I would typically swap the rear end for a 2-way LSD and never had tires more than 8.5" wide on the back. My fastest runs were in the 13's.
With that said today I took out a black BRZ I just completed that is completely stock with a 6 speed transmission. I had spoken to a tuner recently about him almost never being able to get or keep traction, so I wanted to see what he was talking about. So today I opened it up and when I shifted into second the tires actually spun... Then when I shifted into third they chirped. I'm used to a chirp, but not the spin - especially not with only 160hp making it to the ground.
I'm wondering if this traction issue is due to the Torsen LSD in the back? The tuner said he was running stock everything from the transmission back. Anyone out there with a 1.5 or 2 way LSD in the back? Are you having traction issues?
The BlueBaru Turbo Rebuild: http://www.ft86club.com/forums/showthread.php?t=90382
I Rebuild BRZ's for Breakfast.
TurboBRZ is offline   Reply With Quote
Old 07-24-2015, 08:50 PM   #2
D_Thissen
D_Thissen's Avatar
Stock tires?
The Following 4 Users Say Thank You to D_Thissen For This Useful Post:
drewbot (07-25-2015), Pat.Thornton (07-25-2015), Sammakko (07-24-2015), strat61caster (07-25-2015)
Old 07-24-2015, 09:12 PM   #3
Tires...
Old 07-24-2015, 10:06 PM   #4
TurboBRZ
TurboBRZ's Avatar
Yes, stock Michelin tires.
The Following User Says Thank You to TurboBRZ For This Useful Post:
Old 07-24-2015, 10:08 PM   #5
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
there's your answer.
Sammakko is offline   Reply With Quote
The Following 2 Users Say Thank You to Sammakko For This Useful Post:
Old 07-24-2015, 10:26 PM   #6
TurboBRZ
TurboBRZ's Avatar
I didn't realize Michelin was such a poor tire brand...? Or is it just the ones they put on this car?
Old 07-24-2015, 10:31 PM   #7
BlackJesus
Shut up baby, I know it
BlackJesus's Avatar
Drives: 2013 BRZ DMG
They one that they put on your car is an average tire. Traction isn't the best on it. These are meant to tske you from point a to point b and nothing more. I would advise that you get better tires if you want traction in this car.
BlackJesus is offline   Reply With Quote
Old 07-24-2015, 10:35 PM   #8
D_Thissen
D_Thissen's Avatar
They actually are a great tire. Just not on these cars. They are LRR meant for fuel economy, and they do that well. Grip? Ahhhh, not so much lol. They are fun though
The Following User Says Thank You to D_Thissen For This Useful Post:
Old 07-24-2015, 10:44 PM   #9
Sammakko
Bilge monkey
Sammakko's Avatar
you understand that Brand has nothing to do with performance, right? Every manufacturer makes multiple performance categories of tires.
Captain Snooze (07-25-2015), strat61caster (07-25-2015)
Old 07-24-2015, 11:26 PM   #10
stevo585
Drives: White 2014 BRZ
Yep I have pilot super sports and the grip way Better I can no longer chirp or spin any gear. First gear requires a clutch dump to spin. I'm running 245 35r18 though.
stevo585 is offline   Reply With Quote
The Following User Says Thank You to stevo585 For This Useful Post:
Old 07-24-2015, 11:57 PM   #11
wbradley
Sarcastic SOB
wbradley's Avatar
Michelin makes some of the best tires in the market.
The Following User Says Thank You to wbradley For This Useful Post:
Old 07-25-2015, 12:00 AM   #12
Sammakko
Bilge monkey
Sammakko's Avatar
unless you're an autocrosser..
CSG Mike (07-25-2015), strat61caster (07-25-2015)
Old 07-25-2015, 12:04 AM   #13
fika84
fika84's Avatar
Is this thread for real? @TurboBRZ... you take a car with stock tires, roughly double the horsepower and wonder why you have no traction??
fika84 is offline   Reply With Quote
The Following 3 Users Say Thank You to fika84 For This Useful Post:
Bergen23 (07-25-2015), CSG Mike (07-25-2015), drewbot (07-25-2015)
Old 07-25-2015, 12:06 AM   #14
TurboBRZ
TurboBRZ's Avatar
Originally Posted by fika84 View Post
Is this thread for real? @TurboBRZ... you take a car with stock tires, roughly double the horsepower and wonder why you have no traction?? And then you claim that the ENTIRE stock tire brand is garbage because of it??
I took a stock car with stock tires and did a straight run from 1st through 3rd. Nothing modified about the car.
I also have made no claims about Michelin being garbage - if you couldn't tell my post was sarcastic and ended in a question mark. To my knowledge Michelin is a very good brand depending on what you're doing with them.
At 160hp even with the tires it has, it shouldn't spin in 2nd gear - that was an engineering mistake for the designers of this car. Please read next time.
Originally Posted by Sammakko View Post
its a miami thing....
Strange considering I grew up in your back yard. I got tired of the rain and gloom so I moved to somewhere that's always green and sunny year round. Sounds like you could use a bit of sunshine...
TruRace (07-25-2015)
Traction and CEL Light WhiteChocolate Engine, Exhaust, Transmission 25 09-23-2015 09:21 AM
losing traction? sskillzz12 Engine, Exhaust, Transmission 4 03-24-2015 09:51 PM
Traction control help carmen.atil Scion FR-S / Toyota 86 GT86 General Forum 4 12-15-2014 11:14 AM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 03:28 PM
CEL Traction Control ON then OFF HATED1 Issues | Warranty | Recalls / TSB 5 09-24-2012 07:11 PM
