Old 07-23-2015, 10:07 PM   #1
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Scan Gauge
I finished setting up my new "Scan Gauge" today. Now reading RPM, Engine oil temp, Engine water temp, and Automatic tranny fluid temp. Not bad for 170 bucks. It just plugs into the ECU port and will read all sorts of stuff, plus engine codes.
Lunatic is offline   Reply With Quote
Old 07-24-2015, 12:13 AM   #2
Tromatic
Torque and a dongle will do all that and more. Carista will let you clear codes as well as change a few of the car options. I can see the usefulness of a stand-alone doodad but they need far more options to be worth it.
ETA: Did you catch the dude who drove a screw into the faceplate of the head unit? I had to google that. Is that screw stock?
Tromatic is offline   Reply With Quote
Old 07-24-2015, 12:24 AM   #3
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
whats that over the radio????
Old 07-24-2015, 01:00 AM   #4
humfrz
Looks like a CD slot mount for a smart phone or GPS ...... it was "shaking" so he screwed it to the faceplate of his radio screen .......
humfrz
Old 07-24-2015, 01:02 AM   #5
humfrz
Very cool ...... now, you have lots of numbers you can fret over ......
humfrz
Old 07-24-2015, 01:07 AM   #6
Kaotic Lazagna
Drives: GR Corolla
Scan Gauge will let you clear codes as well. I have one and used it to clear codes on my previous car and friend's cars (of course after reading to see what the problem was). I also use it to maximize mpg.
Old 07-24-2015, 06:27 AM   #7
Max FRS
Drives: 2015 Halo FRS Automatic
What X code did you input to get your transmission temperature?
I used the ones I found on line on the scan gauge website but get nothing.
The oil temperature X gauge works great.
Thanks
Max FRS is offline   Reply With Quote
Old 07-24-2015, 07:08 AM   #8
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
I've been using one for a couple years now, primarily for oil and coolant temps. Waiting for a specific car to become available, then the stereo makes way for a proper guage cluster.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 07-24-2015, 08:39 AM   #9
Lunatic
Lunatic's Avatar
CD slot magnetic mount for cell phone.
The Following User Says Thank You to Lunatic For This Useful Post:
WhiteFRS69 (07-24-2015)
Old 07-24-2015, 08:41 AM   #10
Lunatic
Lunatic's Avatar
Thanks
I don't remember. I was on the phone with Scan Gauge for an hour plugging in different codes until we got one that worked.
Old 07-24-2015, 10:55 AM   #11
extrashaky
Drives: 2014 BRZ Limited
Torque will let you clear codes, and it costs less than $30 with a bluetooth adapter. I have added a few more gauges since this pic was taken.:
It also has a page for emissions readiness for people in nanny states:
It can also log your speed and GPS location. You can customize the gauge layout and style. It also uses the phone's accelerometer to tell you how many Gs you're pulling. It can also track 0-60 times. It has gauges for horsepower and torque, but I have no idea how accurate the engine computer's measurement of that is. Plus, when you read codes with it, you can tap them to search on the internet for information about them right on your device's screen.
Plus it looks a helluva lot better. Did I mention it's less than $30?
The Following User Says Thank You to extrashaky For This Useful Post:
Tcoat (07-24-2015)
Old 07-24-2015, 12:48 PM   #12
Lunatic
Lunatic's Avatar
Originally Posted by extrashaky View Post
Torque will let you clear codes, and it costs less than $30 with a bluetooth adapter. 0?
Thats all fine and dandy if your smart enough to get it all running. Stuff like that is way beyond me.
Old 07-24-2015, 01:11 PM   #13
Kaotic Lazagna
Drives: GR Corolla
All good if you don't mind using your phone. I'm just not the type that does. Plus, I've had my SG before that or even the Ultra Gauge came out.
You can get hp from the SG, although I won't trust it since it said my Yaris had over 200 hp. I wouldn't trust anything other than a dyno to show me hp.
Old 07-24-2015, 01:46 PM   #14
Lonewolf
Lonewolf's Avatar
Drives: Moped
I like that mounting point. Aeroforce actually has a scan gauge (Interceptor CNE) for the FRS/BRZ that has interchangeable faceplates that will match just about any FRS/BRZ interior.
http://www.aeroforcetech.com/
Aeroforce Scan Gauge DIE1000DEATHS Electronics | Audio | NAV | Infotainment 5 04-17-2016 05:53 PM
Scan tool ate my TPMS LS1M Software Tuning 4 07-27-2015 08:25 PM
Scan Gauge Help!!! TmP Engine, Exhaust, Transmission 5 05-27-2014 11:09 PM
Scan Gauge 2 - do I need a special version? TmP Cosmetic Modification (Interior/Exterior/Lighting) 5 05-18-2014 11:35 AM
ATI Vent Pod 60mm & PLX DM-200 OBDII Scan Gauge Dustin@Dynosty Engine, Exhaust, Bolt-Ons 2 07-28-2013 01:21 PM
