Old 07-22-2015, 04:50 PM   #1
JG
JG's Avatar
Drives: Whiteout FRS
Unpleasant Sound
I recently Changed my brake pads for all wheels and I was expecting the screech when I brake to go away but it hasn't. Is there something I missed? This was the first time I changed my brakes on my own. All I did was replace the pads
JG is offline   Reply With Quote
Old 07-22-2015, 04:58 PM   #2
wparsons
wparsons's Avatar
What kind of screech is it? What pads did you put on? Did you clean or replace the rotors?
flickr
Old 07-22-2015, 04:59 PM   #3
What kind of pads are you using?
Old 07-22-2015, 05:19 PM   #4
Panman
Panman's Avatar
Drives: 86 GTS
A couple of more minor things -
were there metal plates on the back of your original pads?
On your new ones?
If there weren't metal plates on the new pads, did you move the metal plates from the old to the new?
If you did, did you apply anti-squeal (or a light layer of grease) the back (non-friction) surface of the pads?
If you didn't move the metal plates and they weren't there already, then you should fit them, applying a light layer of grease to the back (non-friction surface) of the pads.
Panman is offline   Reply With Quote
Old 07-22-2015, 06:00 PM   #5
JG
JG's Avatar
On your new ones?
Metal Plates? I think so. It was all one piece. I didn't add any oil or anything? Didn't think that was needed. Should i lube the rotor?
Ceramic Duralast i got from AutoZone
It's coming from the rear tires and it happens when i initially hit the brakes.
Old 07-22-2015, 09:20 PM   #6
DemonRawr
Drives: 2014 BRZ Limited 6M
The screeching noise must be due to the absence of lubricant on the brake pad. Most performance pads comes with lubricant, but you can pick some up from your local auto part shop. They're typically labeled as brake caliper grease or "brake quiet". Just apply a layer of it on the BACK of brake pad (sorry for the misunderstanding...). Kind of sucks since you already went through the trouble of putting in all together already... Good luck!
DemonRawr is offline   Reply With Quote
Old 07-22-2015, 09:42 PM   #7
Panman
Panman's Avatar
Drives: 86 GTS
First of all - never ever apply any lubricant to the friction surfaces - Disks or the face of the pads.
Noise from the rear pads is more unusual than the fronts in this situation, but it seems like you may not have done a pad swap before - I'd get a shop to check it if you are at all unsure.
Old 07-22-2015, 10:27 PM   #8
Poodles
Drives: 2015 Series.Blue
Pad slapping is generally a bad idea... I'm assuming you replaced them because they were worn out? If not, those pads aren't a "high performance" pad.
Old 07-23-2015, 01:26 AM   #9
I'd recommend you take it to a shop; brakes are a core safety component.
Old 07-27-2015, 09:46 AM   #10
JG
JG's Avatar
Originally Posted by DemonRawr View Post
The screeching noise must be due to the absence of lubricant on the brake pad. Most performance pads comes with lubricant, but you can pick some up from your local auto part shop. They're typically labeled as brake caliper grease or "brake quiet". Just apply a layer of it on the brake pad. Kind of sucks since you already went through the trouble of putting in all together already... Good luck!
So i applied the lubricant Autozone sold to me on the back of the brake pads and the screeching is still there. Not only that. Yesterday I heard the noise when i wasn't hitting the brakes. It was even louder while rolling down a hill without hitting the brakes. Now I'm wondering if it is the brakes. It's coming from the rear though.
I changed them because they were worn out. How will i know if they are pad slipping?
It's a simple install. I only swapped the pads. I don't understand where i messed up.
Old 07-27-2015, 10:47 AM   #11
fika84
fika84's Avatar
I guess it could be a wheel bearing, or have something to do with the E-brake shoes.
You can check if it's a wheel bearing, by jacking up the car and trying to move the wheel/tire in a "camber in/out" motion. It shouldn't move, but if the wheel bearing is bad, it will move. Here is more information on how to check.
I haven't had to do anything to the e-brake drum system before, but I'm sure you can find out what to investigate by looking through the service manual.
If you don't feel comfortable, or don't have the right tools. Take it somewhere to have them look at it.
fika84 is offline   Reply With Quote
Old 07-27-2015, 03:15 PM   #12
Put your old pads back on and see if the noise is still there. Process of elimination to diagnose the noise.
Report back after you try it.
Old 07-27-2015, 03:29 PM   #13
STV3
Señor Member
STV3's Avatar
Do our cars have dust shields? (Haven't been down there yet on my FRS) If so, its possible that there is rock or something stuck between the shield and the rotor. Or the shield itself is bent and hitting the rotor.
STV3 is offline   Reply With Quote
Old 07-27-2015, 03:30 PM   #14
CBR600RR
Drives: Raven Black
DO NOT LUBE THE ROTOR!!!!!!!!!!!!!
I suggest you tow your car to a mechanic and get the brakes properly serviced. (if you are seriously asking that question, I highly suggest you do not put your car on the road until a mechanic looks at your brakes, peoples lives could be at risk)
What is this sound? trsiidno Issues | Warranty | Recalls / TSB 5 01-14-2015 06:04 PM
Drone (Worn Wheel Bearing SOund) Sound From Rear qbzee007 AFRICA 8 11-14-2014 01:04 AM
South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway RussellM Northwest 13 09-05-2013 09:57 AM
Sound - ASL ScottKR Electronics | Audio | NAV | Infotainment 0 07-01-2013 10:34 AM
Best sound BAE Engine, Exhaust, Transmission 4 09-30-2012 09:30 PM
