Old 07-21-2015, 09:49 PM   #1
scarfo
Drives: gts 86
How to wire boost solenoid on Aus cars
Hey guys in need of some info, Im in Australia
This is the first 86 my mechanic has worked on, but has a lot of experience with other boosted cars and i trust him with the install, He has just run into a couple of issues installing my treadstone kit.
where to do you wire the ebcs too?
is it the evap solenoid?
Im also having trouble loading on a base map provided with the kit, is this due to them being designed for US cars? or is it because i had previously had my car on the OFT.
need the info as fast as possible
scarfo is offline   Reply With Quote
Old 07-21-2015, 10:25 PM   #2
scarfo
Drives: gts 86
my rom is a ZA1JD00G model code they have supplied a ZA1J700C base tune, can i change anything to make it work
http://www.innovatemotorsports.com/s...T86_Manual.pdf
page 18 is that where you wire the ebcs to on the frs?
Old 07-22-2015, 08:43 PM   #3
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
I wired mine into the EVAP solenoid, which is at the back, driver side of the intake manifold.
crazyfrenchbiker is offline   Reply With Quote
Old 07-24-2015, 10:13 AM   #4
scarfo
Drives: gts 86
Thanks I worked it out
3-port boost solenoid VAC help? Kiske Forced Induction 11 07-19-2016 08:58 AM
Help me identify this wire! Extra wire around battery after clutch job YouShallKnow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 12-09-2014 02:04 PM
Prodrive 3 Port Boost Solenoid rb6freak Engine, Exhaust, Bolt-Ons 0 06-18-2014 12:16 AM
Reverse Wire Tap wire Location? Norkoastal Electronics | Audio | NAV | Infotainment 2 10-19-2012 10:22 AM
The next step in removing feedback from cars: steer-by-wire cyde01 Other Vehicles & General Automotive Discussions 9 10-18-2012 04:00 PM
