I Love custom Turbo kits
Drives: Limited BRZ
Tein Street Flex suspension issue (lowering itself over time)
I have an issue with my suspension. I've had it installed for 6 months. Twice already (let's say 3 month interval between checks), the suspension has lowered itself.
I have tightened the lower ring with all the force I could, having friends help. I've held the two upper rings with the other spanner wrench to tighten the lower ring even more without them moving. It seems simple enough, and I don't see anyone else having that problem. It happens on both fronts. Help??? ![]() @CSG Mike @Racecomp Engineering
#2 |
Drives: '15 Halo FR-S
You using a flathead screwdriver and a hammer to tighten down the lower collar? That could be your problem.
Edit: could be your problem if you aren't using that method to tighten |
#3 |
Drives: Limited BRZ
I did the second time, still happened. The lower collar itself was super tight and almost impossible to get it off today, but that did not prevent the suspension from lowering itself all the way to the bottom.
#4 | |
Either way, I'll be watching this thread to see what the problem ends up being. Good luck with finding the cause. |
#5 |
Drives: FRS
take them off and just sell it to some stance guy and say "it just keeps going lower and lower by itself!"
guaranteed sale.
#6 | |
Drives: Limited BRZ
I hope someone of the suspension experts can come in with an easy problem/solution. Thanks a lot for your ideas!
#7 |
Are the rings clean?
#8 |
Drives: 2015 brz
Subb
#9 |
Drives: Limited BRZ
Not super clean but not particularly dirty. The car has seen rain maybe three times on the six months. I do feel dirt in between the bottom ring washer and the bottom mount. So clean them up good in the contact surfaces?
Sent from my SAMSUNG-SM-N900A using Tapatalk
#10 | |
Also, get a paint pen, and draw a line that goes over the threads, over the rings, and onto the threads on the other side, so you can get a visual reference of if and how much they move. |
#11 | |
Drives: Limited BRZ
Also tighten them as much as possible and use the flathead to tighten more? Sent from my SAMSUNG-SM-N900A using Tapatalk
#12 |
Drives: 2015 brz
You shouldn't be using that, you should be using the keys it came with, if you lost them buy a set their cheap
#13 |
#14 |
I would say nice and firm. You don't want to damage them. Use the provided tools; putting your weight on it should be plenty tight.
| Tein Street flex | JM'sFR-S562 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 05-09-2015 11:04 AM |
| Tein Street Flex installation Help | eguzman6 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 02-08-2015 03:08 PM |
| WTB - Tein Street Flex and some LCA's | Sugi | Want-To-Buy Requests | 1 | 01-25-2015 03:12 PM |
| WTB - Tein Street Flex and some LCA's | Sugi | Want-To-Buy Requests | 1 | 01-25-2015 12:40 AM |
| 25% Off Tein Street Flex's!!! | RallySport Direct | Brakes, Suspension, Chassis | 0 | 12-31-2014 04:52 PM |
