Old 07-17-2015, 01:23 PM   #1
chickencornsoup
Drives: 2013
Error in opening file
I'm having problem after I uploaded the file to OFT. I can't read anything in Download Data and Upload Data from OpenFlash Manger, it show 'Error in opening file'.
Anyone can help please.....
chickencornsoup is offline   Reply With Quote
Old 07-17-2015, 01:25 PM   #2
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
What version of OpenFlash Manager are you running? v1.21.0 is the newest. Also, make sure you are using a USB 1.0 port. USB 2.0 can be a little glitchy on some computers.
Old 07-17-2015, 01:33 PM   #3
chickencornsoup
Drives: 2013
I'm running v1.21.0
it used to be ok with the same usb port.
Old 07-17-2015, 01:53 PM   #4
chickencornsoup
Drives: 2013
It's same ...it can't read info from the device and show 'Error in opening file' on the left bottom corner.
It was ok but after I uploaded the file into it.
Old 07-18-2015, 12:40 AM   #5
chickencornsoup
Drives: 2013
I try on different pc and different usb port, same....
I only use the device 4 times.......
Old 07-18-2015, 12:47 AM   #6
steve99
@chickencornsoup
If openflash manager is connecting to oft and it saying no tune files or original files present.
of thats windows 8 have you loaded windows 8 patch from oft wnlads site ?
try going to upload data and see if you can erase tune files, if no good try below
Then you may be able to try Erasing the entire oft using the erase function.
Just confiming your car is running ok as if the erase of oft is sucessfull you will have to marry up the oft to your car again by reading in an original rom from a working car.
Old 07-18-2015, 01:36 AM   #7
chickencornsoup
Drives: 2013
@chickencornsoup
@steve99
I'm running win7, download data and upload data show the same.
Will it screw up the car by load the original rom back since the OFT not function correctly ?
Thanks for your help
Old 07-18-2015, 01:59 AM   #8
steve99
@steve99
Mate i cannot give you a 100% guarantee something wont go wrong.
but it looks like that the only option left if you try the ERASE function and oft says load original tune
try the ERASE DATA option with oft plugged into computer connected to internet first.
hopefully its just some weird mismatch between old oft software in tablet and the new ofm , just a long shot try loading the updated template file 7.2 i think from oft site
you have not got oft plugged into computer and car at same time as that does not work ?
this is when i like to have my backup device a tactrix cable handy
Old 07-18-2015, 02:21 AM   #9
chickencornsoup
Drives: 2013
Understand....Thanks steve99
Old 07-18-2015, 03:56 AM   #10
chickencornsoup
Drives: 2013
@steve99
I plug OFT to my car and press tunning but is show "File corrupt, weird" then it show "File Mismatch".
It doesn't allow me to write the ECU.
Old 07-18-2015, 07:31 AM   #11
steve99
@steve99
Can you Erase data on oft using ofm and the Erase Data function ?
after that i think your snookered the oft guys may be able to remote reset it maybe
Old 07-18-2015, 08:44 AM   #12
chickencornsoup
Drives: 2013
Can`t Erase data fuction. Already send email to OFT guy, waiting them to reply.
Thanks steve99
Old 11-01-2015, 11:00 PM   #13
bottle
Bump on this thread. This just happened to me and I don't know what's going on.
Thanks
bottle is offline   Reply With Quote
Old 04-26-2016, 03:57 PM   #14
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
BUMP.
I'm getting this same problem right now, anyone ever find a solution?
headlikeahole is offline   Reply With Quote
Strat61Caster's FR-S File (Now an STX build) strat61caster Member's Car Journals 13 12-15-2015 12:57 PM
OFT - Mode file not found. Cannot create a tuning file. focobrz Software Tuning 11 07-17-2015 09:22 PM
which OFT map file to use? BPB stg2 Corradooo Software Tuning 2 06-29-2014 04:09 PM
File Repository? rupert Site Announcements / Questions / Issues 1 01-08-2014 03:46 PM
usb mp4 file format wrohdejr Electronics | Audio | NAV | Infotainment 1 04-16-2013 07:19 PM
