Old 07-13-2015, 10:56 AM   #1
daystall
Disable windows via fuse? [Solved]
I am trying to roll down my windows and disable the buttons during a car inspection because of some window tint issues.
Is there a fuse I can pull that the window motors are on or do I need to pull the harness which is I think ED2 on the drivers side which is listed on page 47 of the wiring manual (BRZwiring.pdf)
Thanks
Last edited by daystall; 07-14-2015 at 05:23 PM. Reason: Mark as solved in the title
daystall is offline   Reply With Quote
Old 07-13-2015, 04:09 PM   #2
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
It looks like you can pull the 25A fuses in the fuse block under the hood labeled D FR DOOR and D FL DOOR
Scenic Driver is offline   Reply With Quote
Old 07-13-2015, 04:15 PM   #3
Speed2th
I love my series blue brz
Speed2th's Avatar
Drives: 2010 335d
you can always open the door panel and unplug the harness. Or you can just put tape over the switch and put warning on steering and window switch for do not open window due to new tint
Speed2th is offline   Reply With Quote
Old 07-13-2015, 04:35 PM   #4
adamg
Drives: brz
pull the fuse, should be good
adamg is offline   Reply With Quote
Old 07-13-2015, 04:42 PM   #5
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
im gonna assume your worried your going to fail inspection if they see you have tint
wouldnt they find it weird if they try to roll up your windows that both dont work????
Old 07-13-2015, 08:01 PM   #6
daystall
Originally Posted by WhiteFRS69 View Post
I’m going to assume your worried you're going to fail inspection if they see you have tint
wouldn't they find it weird if they try to roll up your windows that both don't work????
Maybe, but I don't think it can fail for having windows that don't work.
Old 07-14-2015, 05:22 PM   #7
daystall
Looks like pulling just the D FR DOOR fuse worked. Disabled the windows and the door lock buttons as expected.
And I got that sticker... This BRZ rides again
The Following User Says Thank You to daystall For This Useful Post:
WhiteFRS69 (07-14-2015)
Old 07-14-2015, 05:54 PM   #8
stugray
Drives: 2013 GBS BRZ Limited
Just out of morbid curiosity - How do you plan to respond when they say "Hey your windows dont work"???
Old 07-14-2015, 06:01 PM   #9
I was wondering the same. Here you would fail inspection because the windows didn't work.
Old 07-14-2015, 11:23 PM   #10
HAWAIICALIVEGAZ
HAWAIICALIVEGAZ's Avatar
Drives: HONDA, TOYOTA
Lmfao
HAWAIICALIVEGAZ is offline   Reply With Quote
Old 07-15-2015, 10:12 AM   #11
Scenic Driver
Great. My friend went through the same thing, he didn't have to pull any fuses because the place he used never bothered to roll the windows up. He just always made sure to go on a nice day.
How to disable DRL in FRS whitefrs Cosmetic Modification (Interior/Exterior/Lighting) 12 12-13-2016 02:11 PM
Automatic VSC ABS TRC disable box KenTK808 Electronics | Audio | NAV | Infotainment 0 04-04-2015 06:25 AM
i want to disable the nannies soundman98 Electronics | Audio | NAV | Infotainment 9 02-23-2014 09:25 PM
Can any tuners disable TC/VDC? himbo Software Tuning 52 01-13-2014 10:12 PM
Is there a way to disable the immobilizer? schtebie Issues | Warranty | Recalls / TSB 5 09-22-2012 06:09 PM
