Old 07-12-2015, 09:54 AM   #1
Scoob
Scoob's Avatar
Drives: 2013 FR-S Asphalt
HVT non-raising camber plates
Bought these used off here, but then decided on a set of coilovers that included camber plates before I installed them. These are great for use with stock suspension or with aftermarket suspension without camber plates (like the KW v3 and others).
Asking $375 OBO.
Scoob is offline
Old 07-12-2015, 10:13 AM   #2
redlined600
redlined600's Avatar
Drives: Fr-s
Can you post a pic of the bottom? Does it have a axial bearing?
redlined600 is offline
Old 07-12-2015, 11:44 AM   #3
Scoob
Scoob's Avatar
Not sure what you mean my an axial bearing. It has a spherical (pillowball) bearing. Pic of all the components.
Scoob is offline
Old 07-12-2015, 11:55 AM   #4
Scoob
Scoob's Avatar
Now I get what you're asking. No, there is no other bearing. The metal piece going into the pillowball is joined to the spring tophat by a neoprene-like fitted "washer" that allows the two parts to smoothly turn against each other under load when adjusting the shock body height. Or at least that's what it looks like to me. HVT has some info on their site, but not exactly comprehensive.
Scoob is offline
Old 07-12-2015, 01:35 PM   #5
kodyo
Drives: Scion FR-S
Does this set include necessary hardware for OEM struts? Their website has multiple options depending on whether you have OEM struts or coilovers.
kodyo is offline
Old 07-12-2015, 01:48 PM   #6
Scoob
Scoob's Avatar
These are the ones for the OEM springs. The big silver piece is the upper OEM spring perch. Does not include the rubber ring where the spring rests, but yes on everything else.
Scoob is offline
Old 07-12-2015, 07:16 PM   #7
Scoob
Scoob's Avatar
SOLD! Thanks all!
Scoob is offline
FS: HVT Non-raising camber plates & WL camber bolts trippinbillies40 Brakes, Suspension, Chassis 1 05-16-2015 09:00 PM
HVT BRZ/FRS Non-raising Camber Plate Turn in Concepts Brakes, Suspension, Chassis 25 08-18-2013 03:57 PM
AMR Camber Plates 20firestorm13 Southwest 4 06-09-2013 10:21 AM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
