Old 07-07-2015, 09:29 PM   #1
ChuckButta
Drives: 2015 FRS RS1
Oft and VSC trac, Pedal dance mode question
I have an 2015 Auto with Paddle shifters, and when i hit the trac off button once i go above 36 MPH the trac off turns off. Any way to make the Trac off stay off ?
Also if i put the car in Pedal dance mode does it stay in that mode until i turn the car off ? or is in that mode until i turn it off using the OFT ?
Thanks in advance !
ChuckButta is offline   Reply With Quote
Old 07-07-2015, 09:32 PM   #2
ray7792
ray7792's Avatar
Drives: AT 2013 BRZ Limited
I think once you above 15mph it turns off but anyways, you have to hold the trac button down for like 5 seconds.
The pedal dance mode...I believe is until you turn the car off. Don't think you need to keep the OFT plugged in.
'13 BRZ (sold)
'17 STI
ray7792 is offline   Reply With Quote
Old 07-07-2015, 11:37 PM   #3
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
You do not have to keep the OFT in to stay in dance pedal mode. Once you select that function on a warmed up car, it remains in that mode until you cycle ignition again.
Vsc sport mode and trac off RWD-boxer Engine, Exhaust, Transmission 94 02-25-2020 09:23 PM
OpenFlash Tablet: Pedal Dance Mode Shiv@Openflash Software Tuning 58 05-24-2016 08:52 AM
first time running Slick tires... Pedal dance or normal 5sec trac off? dejxx Tracking / Autocross / HPDE / Drifting 6 11-16-2014 04:07 PM
Pedal Dance Device robot Tracking / Autocross / HPDE / Drifting 3 01-10-2014 09:26 AM
Gas pedal dance brake thing.??? gdrider77 Software Tuning 9 12-22-2013 08:43 AM
