Old 06-19-2012, 06:30 AM   #1
Thefuzz
Drives: 2009 VW GTI <SOLD> 2013 SWP BRZ 6MT
BRZ Limted Door Locks
I noticed that factory config with the keyless entry allows the driver to open their door but does not unlock or allow the passenger to open theirs. Is there a setting to change this? Kind of annoying to have to either pull the key out and use the fob or manually do it as the impatient gf waits lol.
Thefuzz is offline   Reply With Quote
Old 06-19-2012, 08:30 AM   #2
cmspooner
cmspooner's Avatar
Drives: 2013 SWP Limited BRZ - Manual
There is a dealer setting to change the key fob behavior so that a single press opens both doors. I am planning to try to have the dealer set this option with the hope that it also changes the behavior of the keyless entry. I tried to have the setting changed at purchase, but the dealer looked at me like I had three heads...even after showing him the printed page from the manual.
cmspooner is offline   Reply With Quote
The Following User Says Thank You to cmspooner For This Useful Post:
rojas93 (06-08-2014)
Old 06-19-2012, 12:17 PM   #3
Fenrir
Drives: Mazdaspeed 3
There's a small "button" on the door handle you can touch to unlock/lock the door. The touch panel on the inside of the handle only works for the first door to be touched (which is kinda silly, it should open both doors if you're close). If you touch the little button (it's a small raised line in the door handle) it will unlock the door.
edit: p.s. touch touch touch touch touch touch
Fenrir is offline   Reply With Quote
Old 06-19-2012, 04:35 PM   #4
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
For the limited: Open the driver door with the car off, hold down the lock and panic buttons on the key fob for approx 5 seconds. When you let go the car should beep. Now both doors will unlock when you touch the door handle. Not sure if that works with the premium.
sure74 is offline   Reply With Quote
The Following 56 Users Say Thank You to sure74 For This Useful Post:
2pt5RS (06-28-2012), AdamBomb518 (04-01-2015), adamg (03-12-2015), azian_advanced (08-25-2013), benjoke (06-29-2012), bladesamurai (06-20-2012), blalor (06-25-2012), blu_ (06-19-2012), BRZedsDeadBaby (10-03-2016), cmspooner (06-19-2012), cobrabyte (07-26-2012), Dave-ROR (06-19-2012), davesrave (07-04-2012), diddy (06-26-2012), djdnz (08-18-2012), Fenrir (06-19-2012), Ganthrithor (08-31-2013), Guff (08-18-2012), hakkoo (04-23-2013), Hix (07-29-2012), hobojoker (06-02-2014), improvius (07-08-2017), Indestruct (11-16-2012), kgc (09-06-2012), kwood9000 (07-26-2012), lucid215 (07-22-2014), Marchy (09-28-2014), mav1178 (06-02-2014), mechaghost (06-19-2012), MileMonger (01-28-2017), mla163 (08-14-2012), OMNOM (08-21-2012), PandaSPUR (02-23-2015), quality_sound (10-09-2014), racecaresuaceb (11-08-2012), Ramster (06-02-2014), rickitytick (08-16-2012), Sayte (06-02-2014), sdiver68 (06-26-2012), ShoGun (07-01-2012), Sojhinn (03-18-2014), Spaceywilly (06-19-2012), Stierzy34 (08-30-2013), Surok (08-20-2012), SWPinATL (10-18-2013), Thefuzz (06-19-2012), tinma (09-17-2013), tobin (08-31-2013), tonylop33 (09-01-2013), Turbowned (09-01-2013), ubersoph (06-25-2012), Wafflejuice (12-26-2013), wendy86ramos (02-12-2016), Wepeel (03-07-2014), WRXcellent (08-16-2012), Xiijuwa (11-02-2015)
Old 06-19-2012, 05:04 PM   #5
Fenrir
Thought that the keyless entry system was Limited only? Could have read that wrong.
But in any case, thanks a whole mess of gratitude for this (I'm sure I could have found on my own by reading the manual, but hey, why do that if someone else will do it for me right? ).
Old 06-19-2012, 05:22 PM   #6
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Both are keyless. The limited has keyless start and the sensors to open the car without touching the keyfob while the premium just has keyless entry only on the keyfob.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-19-2012, 05:24 PM   #7
Fenrir
Yes, that's what I meant, I should have been more specific. Hands-free keyless? Hafreekeyless? Hafreaky?
Old 06-19-2012, 08:41 PM   #8
cmspooner
cmspooner's Avatar
I didn't see this in the manual, it just had it listed as an option settable by the dealer, that is if your dealer has a clue. Is there a list online of how to set the dealer options?
Old 06-19-2012, 08:49 PM   #9
Thefuzz
Exactly what I needed! Thanks!!
Old 06-19-2012, 08:55 PM   #10
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Smart-key
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 06-25-2012, 06:51 PM   #11
blalor
Drives: WRB BRZ Limited 6MT
This is awesome. How did you figure it out?
blalor is offline   Reply With Quote
Old 06-25-2012, 10:33 PM   #12
Buggy51
Drives: Put Put
Random question, but does the car prevent you from locking the keys inside the car if they are placed in the trunk?
Buggy51 is offline   Reply With Quote
Old 06-25-2012, 10:50 PM   #13
Fenrir
On the limited, the proximity of the keyfob would let you just open the doors, so basically yes
Old 06-25-2012, 10:58 PM   #14
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
There is an antenna in the trunk and if you try to lock it with a key in the trunk it will beep at you and won't let you. I had it happen when I first got my car, I had both keys with me and wanted to just leave one in the car and lock it, it wouldn't let me so I ended up just carrying them both around.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
wheel locks GodSays Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 04:13 PM
Zgrinch's heart just grew 3 sizes! My Limted DGM BRZ is home! Zgrinch Member's Car Journals 68 07-19-2012 03:23 PM
Wheel locks ? MRZ415 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 06-18-2012 12:30 AM
OEM wheel locks? zex BRZ First-Gen (2012+) — General Topics 3 04-14-2012 11:08 AM
Wheel locks? dookie11 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 12-14-2011 09:57 PM
