Old 07-05-2015, 10:54 PM   #1
Hungrr
Drives: 2014 Subaru BRZ
Wastegate Open/Close/Open
Delicious tuned - "Flash N Go" for 12 PSI
FBM turbo kit with Infamous Performance EBCS.
EBCS routed from the Turbo Compressor and ported back into the intake.
At WOT in 3rd gear my boost fluctuates between 12-14 PSI and you can audibly hear the Wastegate open and close repeatedly.
[ame]http://youtu.be/Uz7rzKThYSs[/ame]
Any thoughts?
Hungrr is offline   Reply With Quote
Old 07-05-2015, 11:41 PM   #2
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
The wastegate opening and closing is usually supposed to be audible, especially for an open dump. Yours does seem very slow though, maybe duty cycle frequency is too low in the tune if other hardware is installed correctly. Default is 10hz for EcuTek. That sounds like 1hz lol. I personally prefer like the sound of 15hz which is what the wrx/sti's tend to be.
Just a double check, ebcs port 1 goes to intake pre-maf or atmosphere, port 2 goes to wastegate bottom port, port 3 to boost source. That's my hookup at least. There's more than one way to do it but I see that the most.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 07-06-2015, 02:16 AM   #3
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Talk with Mike and Bill. The tune is handling that boost controller.
rb6freak is offline   Reply With Quote
Old 07-06-2015, 09:59 AM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Just update the name of the tune to "Flash N Go 12-14 PSI Tune". Where are you pulling your boost reference for the solenoid? Performance might improve if you pull it from the compressor housing or close to the compressor housing outlet versus the intake manifold where you are most likely pulling it from.
Old 07-06-2015, 10:05 AM   #5
Hungrr
It was from the intake manifold, I tapped into the coupler at the outlet of the turbo. Same results.
That video is recorded from the outlet boost source
Old 07-06-2015, 01:34 PM   #6
xxscaxx
Drives: 2013 SWP BRZ
Why is the EBCS not routed to the external wastegate?
xxscaxx is offline   Reply With Quote
Old 07-06-2015, 03:25 PM   #7
Hungrr
It is per delicious tunings preferences and website.
Old 07-06-2015, 04:10 PM   #8
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
What is the spring pressure is in the waste-gate and what size waste-gate is it?
Old 07-06-2015, 04:29 PM   #9
Hungrr
39mm precision turbo ewg.
6.9psi springs according to the chart.
Old 07-06-2015, 08:07 PM   #10
xxscaxx
Your first post doesn't say it was routed to the wastegate at all. Was making sure it was, lol.
You can route it that way or how I have it, which is top port & bottom port of the wastegate to the EBCS, and the other line to the compressor outlet.
I have my intake pipe routed to a catch can and the other side is to the CCV, keeping the system closed. Other catch can is PCV.
The Following User Says Thank You to xxscaxx For This Useful Post:
DeliciousTuning (07-06-2015)
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
Windows no longer open/close when door opened NOHOME Issues | Warranty | Recalls / TSB 13 04-18-2014 11:13 PM
JRP open Sunday April 6th-Open House Stav Canada Classifieds 15 04-06-2014 11:45 PM
Is there a way to open/close the windows with the key fob? Zoti Electronics | Audio | NAV | Infotainment 12 09-19-2013 11:43 PM
GrimmSpeed Open House! - Car Show, Open House, Swap Meet - Sept. 28 GrimmSpeed Great Lakes 0 08-27-2013 06:02 PM
