Drives: 2015 WR Blue Sport Tech BRZ
Drivetrain chatter decellerating - 2015 brz M/T
Hello,
I've started a new job recently and every morning I drive into under ground parking, I find when I am driving down the ramp in 2nd gear doing (18-25kph) i periodically hear.. what I could describe best as perhaps a scratching/grinding noise you might here if you jammed a pop can in the flywheel mixed with a diesel engine. Is this normal? Thanks! 2015 WRB BRZ Sport Tech M/T |
That sums up the noises these cars make pretty accurately I would say.
Drives: car
Normal. I hear it more when it's cold out, not an issue when it's warm though.
hey you, yeah you <3
Drives: 2014 37J FR-S
yes, normal! Had it checked by dealer. Normal.
Drives: 4wd zooks
If i roll down a very steep hill in first or second without applying brakes the manual transmission makes some interesting music.
Perfectly normal for these cars and if i listen carefully my manual corolla makes the same noises , only i think it has more NVH insulation. |
| Valvetrain chatter on KW SC FRS | nlowell | Issues | Warranty | Recalls / TSB | 4 | 05-03-2015 11:20 AM |
| Flywheel Chatter | samisons | Issues | Warranty | Recalls / TSB | 13 | 12-05-2014 09:30 AM |
| Drivetrain chatter on cold mornings? | jm1681 | Issues | Warranty | Recalls / TSB | 7 | 10-24-2014 10:48 AM |
| Diff chatter when cold? | BRZrkr | BRZ First-Gen (2012+) — General Topics | 1 | 06-23-2014 09:17 AM |
| Odd Chatter Noise? | Chrisposey | Forced Induction | 5 | 05-05-2014 09:37 PM |
