Old 07-02-2015, 04:13 PM   #1
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
Penske regressive valving
can someone explain to me how they achieve this "regressive" valving characteristics and how it differs from the Ohlins DFV technology? I`m not an engineer and certainly a noob when it comes to reading suspension dyno, but anyone can just look at the curves on the Penske and just imagine how godly it would feel at high speeds...
cut away of the Penske regressive damper
cut away of the Ohlins DFV
this is where it gets confusing to me. I`m sure the Penske stuff is probably leaps and bounds better than Ohlins, but they are both merely a system that allow extra amount of oil to flow when pressure builds? if the way they work is similar, then why is the curve so significantly different?
Example of Penske Regressive damping on Trek Bikes
Ohlins DFV rear
Again, I`m not debating which one is better, but just want to understand the system and the engineering behind the two more.
Suspension gurus please chime in.
mokinbird87 is offline   Reply With Quote
Old 07-02-2015, 06:00 PM   #2
mokinbird87
BOXER FR
found this in a youtube video response from the Trek guys:
Regressive and Digressive are very different things, especially when it comes to compression damping. Regressive damping is compression damping that momentarily DROPS in compression damping as shock velocities increase (when the shock becomes dynamic and continues to move) which allows it to respond to the impact and “shave” the top of the bump off. Regressive is very sensitive to shock velocities. When the shock begins to move and increases in velocity because of terrain input, the valve opens very quickly and there’s an initial drop in compression damping. As shock velocities continue to increase with further shock compression, the valve regains control and introduces progressive damping that offers high levels of damping control. You can see all of this in the dyno graphs that have been presented through the launch of the technology.
Digressive damping is sensitive to compression force and not shock velocity – the valve opens at a specific force regardless of shock velocity. Additionally, digressive damping never decreases or increases in damping force and it’s essentially produces the same amount of damping force from when the valve opens to bottom out – for the most part it’s a flat damping curve. Digressive damping is limited in the ability to produce the efficiency, support and stability desired because as you increase that you also increase feedback and harshness. One thing you are correct on is that Digressive dampers have a tendency to blow through the travel and bottom out harshly – that's because of the flat damping curve they offer. And Digressive damping has been done before by many, but Regressive has not.
Old 07-02-2015, 06:01 PM   #3
mokinbird87
BOXER FR
[ame="https://www.youtube.com/watch?v=jP4Br1FCOBU"]RE:aktiv: All-new mountain bike suspension technology - YouTube[/ame]
Old 07-02-2015, 07:59 PM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
@RBbugBITme
The Following User Says Thank You to cdrazic93 For This Useful Post:
wparsons (07-02-2015)
Old 07-02-2015, 10:34 PM   #5
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Far from a guru... but as an engineer we take complex stuff and simplify it until things make sense. No matter how bogus the assumptions are.
Shim stack are blow-off valves. Build up enough pressure differential and you will deflect the shims and open the flow. Sure, you can build stacks that are digressive, linear, or progressive. You can even have 2 or 3 stage stacks. Normal tech.
The system you're showing is 2-stage. Two elements in series. The big valve acts like a poppet valve. It controls flow to the high-pressure side of the shim stack. This poppet most likely has adjustable pre-load (like how the high-end Ohlins systems work). Additional pre-load keeps the poppet closed until a higher pressure builds.
The characteristics of this damper are probably rigid at low speeds (low force), which creates plenty of stiffness and driver feedback during sweepers. During potholes and transitions, you get into high-speed behavior. The poppet opens, and flow is mostly controlled by the shim stack. Same as before, you can go digressive, linear, progressive, etc.
The comparative stiffness and flow rates of Stage 1 and Stage 2 will make it possible to be "regressive." As some have said, low-speed damping is for the driver, high-speed damping is for the car. You get plenty of sporty feel without jarring your jibblies or over-working the tires.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following 4 Users Say Thank You to Shankenstein For This Useful Post:
chaoskaze (09-22-2015), fika84 (09-22-2015), mokinbird87 (09-22-2015), VerusEric (09-22-2015)
Old 07-03-2015, 09:56 AM   #6
Shankenstein
Frosty Carrot
Ohlins DFV is more of a parallel circuit. 3 paths. Bleed, shim stack or DFV.
It looks like the DFV doesn't allow for much flow, but when it's acting... you probably get a 2-stage response.
The shock dyno definitely looks like you're adding bleed. I'm guessing the DFV is what makes the smooth transition between bleed and main stack action. At full stiff, it's a fairly conventional damper.
The Following User Says Thank You to Shankenstein For This Useful Post:
Old 07-03-2015, 09:59 AM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Oh god that was still kind of rough to decifer
So being regressive is a property of the difference between atleast a two stage flow system? Rather than linear or progressive or digressive which can be in a single stage flow system?
Old 09-22-2015, 12:33 AM   #8
RBbugBITme
Drives: S60R/Corvette
How did I miss this?! Shankenstein's explanation is good'nuff. The only thing I'd add is that we're finding the compression regression is obviously good for big bumps like kerbs and potholes but rebound regression can be equally amazing for maintaining tire contact patch loads over higher frequency inputs like bumpy (washboard) braking zones/corners.
And here is what real curves can look like.
Ryan M.
Strange Engineering
Director of Suspension Development
RBbugBITme is offline   Reply With Quote
The Following 11 Users Say Thank You to RBbugBITme For This Useful Post:
BatStig (09-22-2015), bfrank1972 (09-23-2015), Calum (09-22-2015), cdrazic93 (09-22-2015), CSG Mike (09-22-2015), Dimman (01-08-2016), DocWalt (09-22-2015), fika84 (09-22-2015), mokinbird87 (09-22-2015), Racecomp Engineering (09-22-2015), Wepeel (09-23-2015)
Old 09-22-2015, 02:31 AM   #9
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
@RBbugBITme
Why do you want less compression damping at higher piston velocities? I would have thought (not knowing anything about this stuff) you would want more damping to bring the speeds down.
Old 09-22-2015, 02:34 AM   #10
Captain Snooze
Drives: Red Herring
Digressive damping is sensitive to compression force and not shock velocity – the valve opens at a specific force regardless of shock velocity. Additionally, digressive damping never decreases or increases in damping force [1] and it’s essentially produces the same amount of damping force from when the valve opens to bottom out – for the most part it’s a flat damping curve. [2]
[1] I don't understand this. For air drag it is given (I think) as double the speed square the drag. I'm guessing there is some exponential rise with liquid fluids as well.
[2] These don't look flat to me.
Old 09-22-2015, 02:37 AM   #11
@RBbugBITme
Lets use a track scenario.
If you run over a LARGE curb, the softer damping allows the spring to compress faster (less damping force for the compression), which allows just the wheel to move up, lengthening the impulse the wheel/damper will exert on the chassis, allowing the chassis to stay better settled. The same would apply for large bumps on the road. Although I wouldn't recommend trying it, a speed bump would be a great example where if you went over it at a higher speed than you really should, you won't feel it as much since most of the movement will be in the wheel instead of the chassis.
Captain Snooze (09-22-2015), mokinbird87 (09-22-2015)
Old 09-22-2015, 02:46 AM   #12
RBbugBITme
@RBbugBITme
Not all applications want to blow off high speed compression but as an example...
If your BRZ with linear valving is banging gears down a canyon road and you happen to hit a pot hole with your right front tire, your shock velocity will spike and you'll see a massive increase in damper force. This damper force will unsettle the chassis and effect tire loads on the other 3 tires as well as drastically increase tire load on the right front as it fights the pot hole. All of this is bad and sends you over the cliff.
If you're in the same scenario with regressive damping on the right front corner, your right front tire load doesn't spike as much and your chassis/other tires won't be as affected by what the right front is doing.
All of this is assuming you have enough stroke to absorb the pot hole without making mechanical contact/bottoming out. When you get close to that point you can almost stop caring about grip and you'll hit bump rubbers, hydraulic bump stops, or secondary pistons to save the damper from structural damage.
As for something like a WRC damper, I can't imagine they'll ever run regressive on compression but they'll run it on rebound so the wheels can drop to full droop as fast as possible over every jump thereby giving them the most stroke possible for each jump landing.
Ryan M.
Strange Engineering
The Following 7 Users Say Thank You to RBbugBITme For This Useful Post:
ajc209 (09-22-2015), BatStig (09-22-2015), Captain Snooze (09-22-2015), CSG Mike (09-22-2015), drewbot (09-22-2015), mokinbird87 (09-22-2015), Wepeel (09-23-2015)
Old 09-22-2015, 12:38 PM   #13
mokinbird87
BOXER FR
damn it the more i learn about it the more i want it. i need a 2nd job or something haha.
The Following User Says Thank You to mokinbird87 For This Useful Post:
Old 09-22-2015, 12:38 PM   #14
mokinbird87
BOXER FR
this curve is just sick.
BRZ/FRS ABS Module/Pump/Valving Grambi Brakes, Suspension, Chassis 4 08-22-2015 02:59 PM
More info on Penske shocks ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 156 04-28-2015 10:22 AM
Eibach R2 valving and spring rate question owenxguo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-10-2014 07:43 AM
Penske Coilovers. miwialex Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 12-20-2013 08:17 PM
Penske 8300 vs Ohlins TTX36 CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 09-12-2013 07:08 PM
