Drives: FT-86
Rad Fans doesnt turn on, only when the AC is on
Turbo GT86 with Spal Fans and FB rad with Mishimoto Racing Thermostate. Fans usually come on at around 87C but out of nothing the auto turn on stopped working. Lucky the AC still works and turns both fans at full speed...
Any idea of what could have happened? |
check any relays connected to them or the wiring to the thermostatic switch for the fans. are you overheating?
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
Drives: Firestorm 2013 FR-S
Run a piece of wire between the two wires going to the thermostatic switch to see if the fan comes on. If it does the switch is bad.
If it doesn't check the relay related to the fan.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
| New Wheels - 1 of which doesnt fit right... | imovertheinternet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 04-04-2015 09:31 AM |
| FRS won't Start and doesnt want to idle !!!! | Tboxer | Issues | Warranty | Recalls / TSB | 18 | 12-05-2014 04:25 PM |
| Nameless Down pipe doesnt fit? HELP | The86Ghost | Engine, Exhaust, Transmission | 7 | 05-14-2014 10:27 PM |
| my BRZ doesnt have a USB port, what should i do? | chenshuo | BRZ First-Gen (2012+) — General Topics | 35 | 03-02-2013 05:31 PM |
