Old 11-15-2013, 03:36 PM   #1
brillo
Drives: 2013 Firestorm FR-S
replace stock swaybar bushings - any material handing differnce?
So I was wondering if anyone kept their stock swaybars and just replaced the bushings with a urthane replacement (energy/whiteline etc...).
Did you notice a difference in body roll and handling?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
The Following User Says Thank You to brillo For This Useful Post:
clintavo (11-16-2013)
Old 11-15-2013, 03:42 PM   #2
Racecomp Engineering
You won't notice a difference in body roll, but it may react and load the bar a little quicker. It will be tough to tell from the driver's seat.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Old 11-16-2013, 07:15 AM   #3
solort
Drives: Series 10 FRS
- Andy
If you can find some heim joint end links, they will make the most improvement because they have no play
solort is offline   Reply With Quote
Replace stock muffler? Pacific Auto Engine, Exhaust, Transmission 20 07-21-2014 10:38 PM
Replace shifter bushings? radroach Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-31-2013 10:49 AM
Which ones do you like to replace the stock rikdrt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 11-11-2012 09:53 PM
++PERRIN REAR SHIFTER BUSHINGS NOW IN STOCK! SPECIAL PRICING!++ genometuning Transmission and Driveline 4 10-12-2012 09:23 PM
Replace stock hubs with different bolt patern ones? ahausheer Other Vehicles & General Automotive Discussions 10 02-07-2012 12:24 AM
