Old 07-01-2015, 07:15 AM   #1
Ishmael
Drives: Saab aero
CEL P0852
I have a 13 mt and have had this code a couple of times. I am running a stage one 91 oct tune from my OFT. It seems that this is for an automatic so I am a bit confused. Any help would be welcome.
Ishmael is offline   Reply With Quote
Old 07-02-2015, 01:18 AM   #2
humfrz
Will your car start if the clutch is NOT depressed .... ??
It shouldn't.
I'd suggest you disconnect the negative side of the battery for a couple of minutes to see if the code goes away ...... and doesn't return. Maybe it just "hiccupped".
humfrz
Old 07-02-2015, 11:10 PM   #3
Ishmael
Drives: Saab aero
No it wont start without the clutch down. I have cleared the cel and it comes back in about two weeks. The first time I was just double checking to make sure I wrote the code right because it didnt make sense. That s it though. Ive cleared it again with oft so nothing for the battery to do. Thanks
Old 07-10-2015, 01:19 PM   #4
ilde20
Drives: scion frs
P 852 code
I have the same problem the car was checked by an electrician and said that I have to replace the clutch switches (two) I did but the code appear again, did you find some solution?
ilde20 is offline   Reply With Quote
Old 01-15-2016, 07:07 PM   #5
ilde20
Drives: scion frs
does any one found a solution for this code?
Old 03-26-2016, 03:50 PM   #6
MrStickers
Drives: 2013 Subaru BRZ Premium
Just got this issue after getting my transmission warrantied out. Deleted and came back again twice already.
2000 BMW 323i
MrStickers is offline   Reply With Quote
Old 06-23-2017, 03:33 PM   #7
BRX
BRX's Avatar
Drives: Toyota GT86
I swapped my clutch a year ago when I installed my built block and I had this code appear. I thought it was the ECU freaking out or something so I asked my tuner to disable it as it made my car run weird whenever it shows up every hour or two.
I wanted to install a remote start kit recently that relies on the neutral position switch but when I tested it the signal doesn't get grounded when in Neutral. Double checked with reverse and it was fine. I thought I might just change the sensor but it's about $220. Anyone here solved this issue? Also, is it possible to start the engine with gear in Neutral without pressing the clutch?
BRX is offline   Reply With Quote
