Old 06-30-2015, 05:03 PM   #1
Styx
Drives: Red '12 GT 86
Automatic transmission problem
Okay first of all the car has a Sprintex stage two on and then normal headers with de-cat and then just a normal cat-back exhaust.It has a stage 2 flash from delicous tuning and we have swapped 3 diffrent tunes so we know it is not the tunes.
Now the problem is when i give it the beans,the car seems to select the next gear but doesn't engage it almost like a manual has it's clutch in and revving it.
[ame]http://youtu.be/Z5fGqvOrmjY[/ame]
Styx is offline   Reply With Quote
Old 06-30-2015, 05:32 PM   #2
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
Stock trans? Looks like its got clutch slippage.
Edit: never mind, im clueless......if it was clutches slipping your rpm would still go up......yours seems to get stuck.....perhaps torque converter is locking?
WHITE is offline   Reply With Quote
Old 06-30-2015, 05:48 PM   #3
Rybot
Rybot's Avatar
Drives: Subaru BRZ Series.Blue
Agreed. High torque loads on the clutch will cause this. That's why the invented sport clutches.
Rybot is offline   Reply With Quote
Old 07-01-2015, 04:49 PM   #4
FirestormFRS
1. Check your fluid level
2. Does it do it cold or hot or both?
3. Does it do it in manual or auto mode or both?
If it's engaging the next gear but slow to "take up" it's probably a clutch/plate issue in the oil pump or a sticky solenoid in the valve body.
I'm guessing but that's where I'd start.
FirestormFRS is offline   Reply With Quote
Old 07-01-2015, 08:53 PM   #5
KoolBRZ
KoolBRZ's Avatar
My A/T did this with an SBD turbo on only 7 lbs of boost. That's why I sold the turbo. I'm working on a way to rear-mount a used stock Garrett off an R34 Skyline GTR. It's one of those with ceramic blades that people hate because it starts to break blades over 14 PSI. I picked up 2 of them for $50 each. I want to adapt a muffler delete into the turbo hotside inlet, a tailpipe onto the hotside outlet, a cone filter and adapter on the coldside inlet, and a finned tube going to the front into a Phantom electric supercharger. This will give instant boost, yet when the Phantom peaks and starts to drop off, the rear-mounted turbo will fill in. Best of all, this can all be installed on a stock exhaust with all cats installed, so it will still pass DEQ.
Old 07-01-2015, 08:58 PM   #6
KoolBRZ
KoolBRZ's Avatar
I called that symptom, "all-gears mode" when I had my turbo. It seems to only happen under boost. I couldn't shift up or down with the paddles or the floor shift until I let off the gas. This is why I signed up for the Phantom. The boost is only temporary, and it's much lower. I think the transmission has some kind of torque limiter in the shift controller. That's just the kind of thing that makes me want to crack the code and reprogram it.
Old 07-01-2015, 09:06 PM   #7
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Kris @SSP has been seeing a lot of A/T failures lately under boost. The bad part is that some of the failing parts aren't available anywhere but from a donor tranny. I have his stage 2 valve body and cooler installed. The clutch plate kit is sitting here ready for when those start to slip. I would ping Kris to see if he has any ideas.
nlowell is offline   Reply With Quote
Old 07-03-2015, 02:06 AM   #8
Styx
We already changed the oil 2 times. We think it is electrical but as you suggest it can be a sticky solenoid in the valve body but , wouldnt toyota pick up on that when it was there for the trans problem? It happens very slightly when cold but when hot, it is as aggressive as in the video. And yes it is a stock tranny
Old 07-03-2015, 08:43 AM   #9
onzippy
Drives: 2014 FRS
Thought I broke an axle first time it happened to me (cause I just read the broken axle thread.) but the free revving, no power is the same feeling when I hit the rev limiter.
I've got FI AT also and it just doesn't shift as fast as we'd all like I bet. In manual mode, shifting a little sooner and I avoid it. In Auto mode the ECU doesn't make the same mistakes I do when up-shifting.
Styx, You see the same thing when in 'D' ?
“The thing is, it’s a gearbox, okay? It has one job to do! One job! Pull the lever… ‘Am I a pencil? Am I a cauliflower? Am I a nuclear power station – I’m a gearbox! Oh, heavens, I’m gonna swap some cogs around!’”
onzippy is offline   Reply With Quote
Old 07-03-2015, 11:47 AM   #10
Styx
It happens in D and in manual mode and it happens only in wot, when in manual or in D between 3 and 4000rpm it shifts fast without any problem
Old 07-03-2015, 01:32 PM   #11
WHITE
Thats pretty neat
WHITE's Avatar
I wish I could drive the car to see what it feels like its doing. I really think its something torque converter related though. Just seems from the video that when you shift gear it wants to accelerate but its being loaded down by something cuasing rpm to remain stationary, but then when you lift and re apply throttle the load goes away and it accelerates like normal then.
This is just from what I'm seeing and hearing though, its hard to give definite diagnoses over the internet. Do you have any way to log or visual see what's going on via a tablet or something?
Old 07-03-2015, 01:39 PM   #12
onzippy
Drives: 2014 FRS
So if you stay between 3-4k and do WOT shifts does it still slip?
Just trying to get idea if it's only high RPM and WOT = slip.
I dyno'd 250whp on 93 but now with e85 and cranked up boost I don't even know how much power's there but I haven't had any problems except kissing the rev limiter like I said. knock wood..
Old 07-04-2015, 02:18 AM   #13
Styx
We keep our foot planted in the video we never take it off it just engages when it wants too.i do have logs with ecutec software but that is at the guy that does my reflashes.
Old 07-04-2015, 02:20 AM   #14
Styx
Normal 3 to 4k driving it doesnt happen only when in wot and in high rpm it does that. The car only puts 158kw too the wheels so i dnt know why its giving us this crap
Shifting Problem (Automatic) FRSure Issues | Warranty | Recalls / TSB 61 05-09-2021 07:38 PM
AUTOMATIC TRANSMISSION FLUID? How many L ScionFR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 02-21-2015 12:43 AM
Automatic Transmission devinclfalcons Engine, Exhaust, Transmission 60 04-29-2014 09:42 PM
Automatic Transmission :( Almighty Bob Southern California 14 11-06-2012 01:13 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
