Old 06-30-2015, 03:52 AM   #1
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Thumbs down This normal sound for clutch on all twins?
First, sorry for perhaps a issue already posted, but i've sat on the toilet many times for the past few days searching the forums and googling...
So, is this a sound you fellow members experience when hitting clutch. I have it in mine when hot and cold start. I may also believe my clutch is slipping.
Sound is when the vid poster begins to engage clutch in neutral. 0:35
[ame="https://www.youtube.com/watch?v=6rYKte0ll28"]Scion FRS clutch engagement issue - YouTube[/ame]
p.s. someone mentioned its caused by a/c... uhm nope...don't relate imo.
Packofcrows is offline   Reply With Quote
Old 06-30-2015, 07:09 AM   #2
Itzed
Drives: 2014 BRZ Limited
I don't have any sounds like that when operating my clutch (15K miles).
Itzed is offline   Reply With Quote
Old 06-30-2015, 10:49 AM   #3
Purdue FR-S
Boiler Up!
Purdue FR-S's Avatar
Drives: 2018 BRZ tS
Mine does this .... I think...
Purdue FR-S is offline   Reply With Quote
Old 06-30-2015, 10:51 AM   #4
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
nope, mine doesnt do that
bring it to the dealer
The Following User Says Thank You to WhiteFRS69 For This Useful Post:
Packofcrows (07-02-2015)
Old 06-30-2015, 12:39 PM   #5
Teseo
Drives: frs
Mine does when cold, maybe release fork?
Old 06-30-2015, 01:39 PM   #6
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Points if you posted this thread on the toilet.
Instagram: stimson
The Following User Says Thank You to Turbo95eg6 For This Useful Post:
Old 06-30-2015, 01:42 PM   #7
Was going to go out and see if mine did it. Walked to the door. Looked out in the parking lot. Said "shit". Turned around and sat back down.
Pretty sure mine doesn't make that noise though.
JellyForSale (06-30-2015), meWant (06-30-2015), Packofcrows (07-02-2015), shifter907 (07-01-2015)
Old 06-30-2015, 02:04 PM   #8
Packofcrows
I did...
Thanks guys for the quick answers. Taking it in tomorrow morning.
The Following User Says Thank You to Packofcrows For This Useful Post:
Turbo95eg6 (06-30-2015)
Old 06-30-2015, 02:52 PM   #9
JB86'd
JB86'd's Avatar
Drives: JAWS
Does it do it when the car is off? That may help isolate what it could be.
Old 06-30-2015, 02:54 PM   #10
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Mine actually does make that noise when you step on the clutch pedal, engaging it and disengaging it. On or off, hot or cold.
Bach415 is offline   Reply With Quote
Old 06-30-2015, 03:08 PM   #11
Packofcrows
Yes sir, when off, on, hot or cold. BRB let me get a vid for you guys.
Old 07-01-2015, 01:00 PM   #12
Packofcrows
Update:
Went on ride with tech. Found it might just be spring. Tech will check slave cylinder, clutch assembly, pull transmission and check.
Found that car is pulling to sides again as well. Might be here for 5hours. Zzz...
Old 07-01-2015, 01:03 PM   #13
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
It's totaled. I'm sorry.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
Manic is offline   Reply With Quote
The Following User Says Thank You to Manic For This Useful Post:
Packofcrows (07-01-2015)
Old 07-01-2015, 01:29 PM   #14
Ramster
Ramster's Avatar
Drives: Subaru BRZ Limited
Mine makes that sound, although probably not as loud. I have ACT lightweight flywheel and clutch kit installed. Did it before and after the new clutch job.
Ramster is offline   Reply With Quote
The Following User Says Thank You to Ramster For This Useful Post:
Clutch release sound...is this normal? Decimus Southern California 0 06-20-2015 01:23 PM
Clutch Vibrates at high RPM Shifting, normal? Error Issues | Warranty | Recalls / TSB 6 08-03-2014 02:25 PM
Is this a normal sound? amilleri Issues | Warranty | Recalls / TSB 16 05-22-2014 02:14 PM
Cricket sound while running, normal? Zzzquil Issues | Warranty | Recalls / TSB 13 02-13-2014 12:59 PM
3-4 weeks for a white/manual frs sound normal? jacobzking Scion FR-S / Toyota 86 GT86 General Forum 20 05-28-2013 09:06 PM
