Old 07-30-2014, 01:37 PM   #1
Error
Error's Avatar
Drives: FRS
Clutch Vibrates at high RPM Shifting, normal?
Hey, quick bit of information. This is my first manual car so this may be normal, but I feel like it isn't. When shifting at rpm north of 4500ish (tested in 2nd, 3rd, and 4th gear), when I push the clutch pedal in I can feel the vibration of the rpm's dying down. I don't know if that makes sense, but I can basically feel the clutch vibrations die down with the rpm (ie heavy vibration at around 6000, starts to disappear as the rpm's progressively reach down to about 4000ish and then disappearing altogether. The car has currently 4400km on it. From what I understand, when I clutch in the engine should be disconnected from the wheels and I shouldn't feel this sort of vibration through the clutch pedal that lines up with the engine rpm. I apologize if it is normal, but I am concerned about this issue. I am looking for opinions, and if it is not normal I will be booking an appointment with my nearest dealer. Thank you.
Error is offline   Reply With Quote
Old 07-30-2014, 01:53 PM   #2
mike the snake
Definitely take it to your dealer.. Especially with the low miles, there should be no vibrations whatsoever.
It could be a number of things, but something is out of balance, or loose, go to your dealer ASAP.
Old 07-30-2014, 07:08 PM   #3
Error
Error's Avatar
Drives: FRS
Thank you, I have booked an appointment with my toyota dealership on Friday. Will update on results in case someone else in the future has a similar issue.
Old 07-31-2014, 09:24 PM   #4
Aerok
It's Korea backwards.
Aerok's Avatar
Drives: 2014 FR-S Whiteout
I've experienced something similar to this. Whenever I press the clutch to shift I get a vibration and a "scraping feeling". It doesn't do it all the time and only past 4000rpm.
I took it to Toyota and had 2 separate techs drive it. Their diagnosis was "Your car is lowered and has an exhaust, that's why you feel the vibrations."
I'm not saying I believe them, but that's what I was told.
My previous car was a 240SX. I had coilovers and a full 3" exhaust. No vibrations like the ones I feel now ever occurred. Go figure.
Aerok is offline   Reply With Quote
Old 08-03-2014, 12:55 PM   #5
Error
Error's Avatar
Drives: FRS
Quick update, and then the thread could be closed maybe? Tech said something along the lines of "its vibration coming through the tires and your exhaust" but I think it might just be something else. They checked the transmission and said everything was working as it should and to not worry about it. Hopefully they're right. Thanks for the replies.
Old 08-03-2014, 01:06 PM   #6
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
I don't know how the vibration can come from your exhaust if you have them in the hangers correctly.
Tires? stock tires or are you running on thinner tires and are the wheels balanced and aligned? (if yes, then he's full of shit)
CamryDS is online now   Reply With Quote
Old 08-03-2014, 01:25 PM   #7
Error
Error's Avatar
Drives: FRS
Stock everything atm. Wheels are exactly as they are since I bought the car in may. And yeah, I felt like he was just offering a half-assed answer.
Hard shifting into first gear; normal? blalor Engine, Exhaust, Transmission 54 08-31-2017 09:57 PM
whining/whirring noise during high load/rpm clutch engagement 7thgear Issues | Warranty | Recalls / TSB 105 06-19-2017 11:04 AM
High clutch catching point scionfrs2014 Scion FR-S / Toyota 86 GT86 General Forum 38 12-26-2013 10:39 AM
Clutch realeses really high jonbonazza Issues | Warranty | Recalls / TSB 12 12-02-2013 08:12 PM
High RPM Shifting Issue? Rinzler Issues | Warranty | Recalls / TSB 5 05-17-2013 12:30 AM
