Old 06-30-2015, 12:03 AM   #1
azynneo
Went back to stock, different AFR?
So I went back to stock from JDL and as I accelerate my AFR normally reads 14.5 on average and doesn't move much while on my JDL. Now I'm back on stock and as I accelerate it drops down to 11.1 and sits there until I shift back up. Is this normal since there is more air restriction?
azynneo is offline   Reply With Quote
Old 06-30-2015, 12:09 AM   #2
Turdinator
Señor Member
Turdinator's Avatar
JDL what? Header? EL or UEL? Cat back? Font pipe? Overpipe?
1974 TA22 Celica
2013 86 GT
Old 06-30-2015, 12:09 AM   #3
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Were you going WOT with the JDL header and seeing 14.5 AFR? What tuning are you using?
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 06-30-2015, 12:11 AM   #4
azynneo
UEL Headers, Perrin cbe, frontpipe is catted, jdl overpipe
Old 06-30-2015, 12:12 AM   #5
azynneo
Yes, I was going WOT, using Bills 8.88 Delicious Tuning tune
Old 06-30-2015, 12:17 AM   #6
steve99
Back to stock tune as well with stock header ?
Stock tune runs quite rich targets 10.7 afr high rpm wot
Most tuners would target arround 12.5 afr wot on petrol, 14.5 is way lean for petrol wot high rpm suspect you had air leak near 02 sensor or something weird going on
Old 06-30-2015, 12:18 AM   #7
Turdinator
Señor Member
Turdinator's Avatar
Did you change tune when you went back to stock header?
1974 TA22 Celica
2013 86 GT
Old 06-30-2015, 12:18 AM   #8
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
I'm assuming you flashed back to stock tune.
Edit: Well seems a couple of us were typing at the same time.
WHITE is offline   Reply With Quote
Old 06-30-2015, 12:20 AM   #9
azynneo
The tune is still at 8.88, according to Zach it's safe to stick at the current tune I have right now. I'm at a stage 2 supercharged tune
Yes sir,
All good to return to stock exhaust.
On Tue, Jun 16, 2015 at 11:41 AM, azynneo@aol.com <azynneo@aol.com> wrote:
Zach,
Is the stage 2 innovate 8.88 tune safe if i ever go back to all stock?
(forgot to mention I'm supercharged)
Old 06-30-2015, 12:24 AM   #10
Apoc
Apoc's Avatar
Did it stay that high for the whole RPM range? if so that is way too lean. If you are back to a stock tune I would expect to see a rich AFR like 11. What intake do you have?
“The World is Flat”
[||•]=(86)=[•||]
Old 06-30-2015, 12:26 AM   #11
azynneo
When I'm cruising now it stays around 14-15. When I go WOT it drops to 11-12. I'm using stock intake with a drop-in filter.
As for the JDL's I would go WOT and I'd hit maybe 13.8-14 there would be a very small chance I'd hit anything lower than that.
If this is normal it'd be nice, I was just afraid of my crap blowing due to low afr.
Old 06-30-2015, 12:28 AM   #12
Apoc
Apoc's Avatar
You are supercharged?
“The World is Flat”
[||•]=(86)=[•||]
The Following User Says Thank You to Apoc For This Useful Post:
D_Thissen (06-30-2015)
Old 06-30-2015, 12:34 AM   #13
WHITE
Thats pretty neat
WHITE's Avatar
You got it backwards. You want a lower afr with forced induction. Your 14-15 afr is bad. Thats a lean condition, meaning your risking detonation.
Old 06-30-2015, 12:35 AM   #14
Apoc
Apoc's Avatar
You need to go to a tuner. Running 14 AFR with FI is bad. You seem to have little knowledge on what you should be expecting for datalogs on a supercharged FA20. You need to get educated.
“The World is Flat”
[||•]=(86)=[•||]
OFT back to stock dejxx Software Tuning 13 01-30-2020 03:15 PM
PA:Back to stock shultz2 Brakes, Suspension, Chassis 35 06-20-2015 09:03 PM
WTB: Stock cat-back jonbonazza Want-To-Buy Requests 1 05-06-2015 03:34 PM
FS/FT: Going back to Stock [deleted] Southern California 23 10-02-2014 11:38 PM
