Old 10-03-2014, 09:23 AM   #1
UrmyboyBLUE
UrmyboyBLUE's Avatar
Drives: 2015 Subaru BRZ "Series.Blue"
Advanced Multiplier??? What is it?
I recently ran the OTS stage 2 EL E85 tune on my car, yet I didn't notice the advanced multiplier moving off of "0" at any point...should it be?
UrmyboyBLUE is offline   Reply With Quote
Old 10-03-2014, 09:27 AM   #2
lucid215
if it moves then its pulling timing. it stayying at 0 is what you want it to
lucid215 is offline   Reply With Quote
Old 10-03-2014, 09:31 AM   #3
1Cor10:23
1Cor10:23's Avatar
Advanced multiplier should read 1 (in most cases; your zero could just be the a template issue if you're on OFT).
It's used to adjust your timing advance (usually more timing = more aggressive tune) to compensate for fuel quality. It can go anywhere from 0 (really bad) --> 1 (ideal).
When your ECU detects knock, it will lower the multiplier.
Think of multiplier as percentage of timing applied. 0-1 --> 0% - 100%
Let's say at 3000 RPM, your tune calls for 40 degrees of timing. If you're on good gas as prescribed by the tune, your IAM should be 1 or at least close to it. You'll get 1.0 x 40 degrees = effectively 40 degrees applied.
If you're on lower quality gas, ECU detects the knock, and drops your IAM - it will keep dropping until ECU determines that the resulting level of knock after adjustments is within safe limits.
Example: knock detected, IAM drops to 0.7 --> 70% of 40 degrees = 28 degrees applied.
There's always a debate as to whether a tune should be optimized for potential (on ideal fuel) and let ECU compensate for poor fuel by dropping IAM OR to optimize for effective fuel (target IAM to always be at 1.0; drop timing a bit since fuel is never perfect - also regional differences).
Someone correct me if I got any of this wrong!
Old 10-03-2014, 09:51 AM   #4
UrmyboyBLUE
So your saying..with the E85 tune loaded...if I do a 3rd gear pull to redline, I SHOULD see the multiplier move to "1"?
Old 10-03-2014, 09:59 AM   #5
s2d4
s2d4's Avatar
It should be at 1 to begin with.
Old 10-03-2014, 10:00 AM   #6
bfrank1972
Drives: 2013 FR-S Argento
No:
If your OFT is reading advance multiplier of "0" then something is slightly misconfigured with your OFT (fixable, contact Vishnu)
If your OFT is reading constant "1" you are good to go.
If your OFT is reading somewhere between 0 and 1 then you're having knock, which means the engine isn't happy and there might be an issue with your fuel (or otherwise).
bfrank1972 is offline   Reply With Quote
Old 10-03-2014, 05:43 PM   #7
steve99
if your on D00C/D rom the advance multiplier was not logging correctly i believe the oft guys aware of this ad may have fixed it. plug your oft into your computer connected to internet and run the oppenflash manager OFM software and let oft get its updates from openfash then all shud be good
have a read of the lks below especiay on knock correction and loogging will tell you what to look for
Old 10-13-2014, 08:54 PM   #8
benlaz88
Drives: 2013 Asphalt FRS
Can anyone help me out with this chart. This is my first log for E85 EL stage 2 tune. I don't know why my Adv multiplier keep dropping? Can anyone take a look for me? I would appreciated.
http://www.datazap.me/u/benlaz88/1st...-9-10-11-13-14
Ben
benlaz88 is offline   Reply With Quote
Old 10-13-2014, 09:05 PM   #9
steve99
Ben
Dropping due to Knock correction at lower rpm 2000-3000 rpm
http://www.datazap.me/u/benlaz88/1st...8-9-12&solo=12
If its your first tank of E85 probably due to residual petrol.
If not you may need to pull 0.35 or 0.7 degrees out of the base_timing_B map from 2000-3000 rpm engine load 0.5 to 1.0 where your seeing that knock
Why does my Advance Multiplier keep dropping? jeebus Software Tuning 103 10-17-2016 05:29 PM
Advanced driving. paulca Other Vehicles & General Automotive Discussions 180 01-13-2015 10:02 PM
Advanced driving course tm86 AFRICA 43 01-03-2014 03:14 AM
Displaying the Adv Multiplier sw20kosh Software Tuning 12 12-09-2013 10:42 PM
Multiplier and offset for OMNI 2.5 bar map sensor? ATSAaron Forced Induction 2 10-28-2013 11:16 AM
