Old 06-29-2015, 03:48 PM   #1
tracerit
Drives: '13 SSM BRZ Limited 6MT
Michelin pilot super sport :normal wear?
Hi I've been driving ok Michelin pilot super sport tires for the last 4k miles and wanted to know if the following wear is normal. Attached are two pictures. The front and rear tires are both wearing faster in the middle with the rear wearing quicker most likely being RWD. Looking online it seems that this is common which led me to see if this is in fact normal or not?
Front http://i.imgur.com/tKOG4XT.jpg
Rear http://i.imgur.com/geGfdON.jpg
They were inflated 39psi when installed by the tire shop but 2k miles in I switched to 35/31 f/r.
tracerit is offline   Reply With Quote
Old 06-29-2015, 05:18 PM   #2
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
What size tires are you running? For factory wheel size/tire size, isn't 35/35 psi recommended? 39 PSI is a little high, so that could lead to it wearing in the middle. Why are you running 31 PSI in the rear now?
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
tracerit (06-29-2015)
Old 06-29-2015, 05:31 PM   #3
tracerit
I'm on 235/45/17 Michelin pss on 17x8.25 wheels.
I lowered it a bit thinking because it was over inflated causing the increased wear on the middle.
Old 06-29-2015, 06:09 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I run 32 psi on my 245/40/17 MPSS. I have very even wear and am at 21,000 on fronts and 16,000 on rears. I have new ones ordered...
Old 06-29-2015, 06:22 PM   #5
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
I also ran my pilot super sports at 32 psi hot. My sizes were 255/40r18 front 265/40r18 rear. Tires wore even on all four corners, id say your problem was becuase you ran them at 39psi, thats too high imho.
WHITE is offline   Reply With Quote
The Following User Says Thank You to WHITE For This Useful Post:
Old 06-29-2015, 06:32 PM   #6
tracerit
ah, so it seems now that the wear is abnormal and most likely attributed to the 39psi that you've all mentioned. My 35/31 f/r were measured cold btw. I'm gonna check out the tire psi thread but will most likely go to 32psi all around and see how that works out.
thanks all!
2x Michelin Pilot Super Sport 215/45 ZR17 hachi roku [86] Wheels and Tires 2 06-04-2015 06:10 PM
Michelin Pilot Super Sports Wear Question tonystewart Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 09-04-2014 10:03 PM
Michelin Pilot Super Sport 225/40/18 FastLane1000 Wheels and Tires 2 09-03-2013 12:04 PM
Michelin Pilot Super Sport - 245/35ZR18 Staf00 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 08-30-2013 06:13 PM
Michelin Pilot Super Sport 17 inch DieselBoXXer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-05-2012 10:17 PM
