Old 06-23-2015, 01:23 AM   #1
LXXXV1
LXXXV1's Avatar
Drives: 2014 FR-S Monogram, Whiteout 6MT
DIY $5 reversible always-on for FRS 10 Series, Monogram, RS 1.0 or JDM headlights
First DIY. Building up to my footwell and courtesy light DIY. Be gentle. I know there are other write ups but I didn’t see an official DIY in the directory with a good step by step so I made this. I'm not responsible for any damages done to your car during install. This is a fully reversible ~$5 DIY solution for the DRL always-on mod for those with a 10 Series, Monogram, RS 1.0, or JDM headlights.
For the record, different ohms (100, 200, 300, etc) allow for different brightness. For this example, I used a 10 watt 100 ohm resistor.
Special thanks to @Phil_FRS for letting me use his car as an example. And @Siege for his DIY, found here. (This is essentially what he did but with detailed pictures as I kept getting questions/requests about what I did)
Time required: ~10-30 minutes
Skill level 1=noob to 5=expert: 1.5
Parts/tools required:
1 x 10 watt 100 ohm resistor (~$5 at typical lighting hardware store)
2 x small sunglass flathead or screwdriver
1 x wire stripper
1 x needle nose pliers
Figure 1: Resistor and small screwdrivers
Step 1: Open hood. Find passenger side headlight. Locate and disconnect headlight harness. (Unclip from the bottom and wiggle it loose)
Figure 2: Passenger headlight connection
Figure 3: Close up of passenger headlight connection.
Step 2: Gently pry out the white plastic piece with small flathead. It comes straight out/up pretty easily.
Figure 4:
Close up of 8 pin harness.
Figure 5: Close up of the flathead prying out white plastic piece.
Step 3: Use small flathead to press up on the plastic clip and push metal pin in until it comes out the other end.
Figure 6: Close up of flathead pushing clip up for the top red wire.
Step 4: Repeat for the bottom brown wire. The two wires that are removed are the red and brown wires on the right side. See circles in figure 7.
Figure 7: Circles of the two pins to remove.
Step 5: Strip ~1” of wire from both ends of resistors. Wrap both ends around the two unpluged pins. LEAVE enough exposed wire so you have room to plug it back in. See figure 8.
Figure 8: Stripped resistor wrapped around pins.
Step 6: (No picture) Use needle nose pliers and plug wires back in. May require some force. Make sure you leave enough exposed wire so you have room to plug it in. You should hear a small audible click.
Step 7: Reassemble everything, zip tie resistor to frame, and go for a drive!
Figure 9: Zip tie resistor to frame
Figure 10: Finished product
LXXXV1 is offline   Reply With Quote
Old 06-23-2015, 02:20 AM   #2
sillierabbit
Drives: 2014 FR-S Monogram Whiteout AT
How come I can't see the pictures?
sillierabbit is offline   Reply With Quote
Old 06-23-2015, 03:15 AM   #3
LXXXV1
LXXXV1's Avatar
Should be fixed.
2007 Honda CBR600RR-Pearl White/Silver - Totaled
2014 Scion FR-S Monogram-Whiteout - #LXXXV1 (build)
φφκα
Old 06-23-2015, 12:04 PM   #4
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
Good DIY simple and many picture~
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 06-23-2015, 10:08 PM   #5
Phil_FRS
Phil_FRS's Avatar
Drives: 2014 FRS Monogram
Many thanks to LXXXV1 for his excellent installation. Love the end result. Clean look. Two thumbs up for service to the community.
Phil_FRS is offline   Reply With Quote
Old 06-23-2015, 10:09 PM   #6
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
You should put a diode in series with the resistor to prevent backflow to the #5 (red, headlight) when the DRL is on and not the headlights.
aegisdrgn is offline   Reply With Quote
Old 06-24-2015, 06:26 PM   #7
Pat.Thornton
Pat.Thornton's Avatar
Drives: 2014' 86
You mention this will work for "JDM Headlights", would this include headlight such as the JDM winjets for the frs?
Pat.Thornton is offline   Reply With Quote
Old 06-24-2015, 06:33 PM   #8
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Damn A+ write up.
Old 06-24-2015, 07:47 PM   #9
LXXXV1
LXXXV1's Avatar
Good thinking. Will update soon when I do this. Thanks.
Sorry, I'm not sure how the winjets are wired. Assuming it has the same harness connection, it might? At least you can use this write up to easily install and test it out! At your own risk though lol. Probably safer to try it with the diode though, which I will update shortly.
φφκα
Old 06-24-2015, 11:12 PM   #10
Pat.Thornton
Drives: 2014' 86
Ok I'll give it a shot
Old 09-10-2015, 01:52 AM   #11
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Sorry to revive a dead thread but just bought the DRL mod for the winjet "JDM" headlights:
[ame="https://www.youtube.com/watch?v=n-NztsSDBj0"]DRL mod - YouTube[/ame]
Seems he does something similar to the wiring connector involving switching the two wires at the connector as well as an inline resistor
Old 09-11-2015, 09:21 PM   #12
mid_life_crisis
Drives: FR-S 10 #103 AT
You want to solder those wires. Leaving them loose like that is begging for trouble. You can always reverse it by snipping them off with sidecutters.
Old 09-13-2015, 12:16 AM   #13
LXXXV1
LXXXV1's Avatar
Why would there be trouble if none of the wires are exposed? Everything after the rubber grommets are securely plugged into the socket. And I mean securely...you need pliers to properly reinsert the 2 prongs to hear that snap because of how little room there is. If you splice/solder it in before the rubber grommets, then it's not exactly 100% reversible. You'll forever have marks on the wires to show you modded it, i.e. good bye warranty unless you completely replace the wire you spliced to hide all signs of modification.
φφκα
Old 09-13-2015, 11:58 PM   #14
mid_life_crisis
There is a fair amount of current in that connection. Wires should not be left in a condition where they have the potential to move at their contact point like that.
Monogram series headlights on a FRS DCStorm Scion FR-S / Toyota 86 GT86 General Forum 15 12-07-2020 04:59 PM
Monogram/ Series 10 Headlights fitcious Cosmetic Modification (Interior/Exterior/Lighting) 130 06-10-2016 10:07 AM
Monogram/10 series Toyota headlights with adapters Calavera Exterior Parts (Aero, Lighting, Etc.) 8 05-10-2015 08:46 PM
Monogram Series Headlights. SOLD JDis3 Exterior Parts (Aero, Lighting, Etc.) 6 11-03-2014 12:16 AM
FS BNIB Series 10/ Monogram Headlights ecda Exterior Parts (Aero, Lighting, Etc.) 5 09-30-2014 06:28 AM
