Old 06-23-2015, 12:31 AM   #1
Vinsanity091
Drives: 2015 Firestorm FR-S M/T
BBK purchasing question
I apologize if this has already been answered, but I did some forum searching and couldn't find this question answered anywhere yet.
When purchasing a BBK from AP Racing for instance, how many wheels are covered by the BBK? Are they divided up one kit/wheel, one kit for either the front wheels or rear wheels, or are all four wheels covered by a single kit?
Example of what I'm talking about:
http://www.stillen.com/product/brake...0r-141786.html
I notice that it says front kit on the website, but how would you go about getting a rear kit if this is front wheel specific only? Also, I'm not sure if front kit does in fact mean the front wheels. Sorry if there is a really obvious answer, but I'm new to learning about brakes and I'm looking to upgrade so I wanna make sure I get it right. Thanks!
Vinsanity091 is offline   Reply With Quote
Old 06-23-2015, 12:39 AM   #2
ryoma
ryoma's Avatar
front kit usually means both front wheels. rear kit is both rear wheels. to buy the rear brakes, look for a rear brake kit. you should probably keep in mind whether or not you want the e-brake since some "race" BBK's might get rid of the e-brake
however, you would probably benefit more from upgraded pads and fluids (maybe braided lines) rather than a full on BBK. the BBK is more for pure track racing or the bling factor. most people have their needs met with upgraded pads and fluids/lines for the occasional track day
Old 06-23-2015, 05:53 PM   #3
Kits are generally done per axle.
If you purchase a front BBK, it's for both front wheels. If you purchase a rear BBK, it's for both rear wheels.
Old 06-24-2015, 07:27 AM   #4
Rafi@RR-racing
Rafi@RR-racing's Avatar
Drives: Toyota GT86
A lot of BBK manufacturers do not even have rear kits. I could be mistaken, but I don't think Stillen ever developed a rear application, which shows you how serious they are about developing brakes for the BRZ.
We have 6 different BBK options, including rear as well. All have been track tested and our 6 piston front, 4 piston rear combo is about the same price as Stillen 6 piston fronts only.
http://www.rr-racing.com/category-s/130.htm
thanks!
Rafi
Rafi@RR-racing is offline   Reply With Quote
Old 06-24-2015, 10:39 AM   #5
cslntuee
Drives: Subaru BRZ Limited
Any option of dust boots for DD usage?
Thanks.
cslntuee is offline   Reply With Quote
Old 06-24-2015, 02:16 PM   #6
Rafi@RR-racing
Drives: Toyota GT86
Thanks.
Hi... I can assure you that the lack of dust boots is a non-issue. None of Wilwood street focused BBK's use dust boots, and I have not heard of any issues. In fact, the Forged Narrow Superlite 6R calipers we use in our Stage I and III kits are powder coated, and are primarily geared for street use with occasional track use. Powder coating (whether on Wilwood's, Brembo's, AP's, etc) does not hold up well to track use as it will literally melt over 350-400 deg. F.
In some ways the lack of dust boots reduces maintenance if you ever track your car... as the rubber dust boots either melt or dry up and crack. Our shop IS-F has Brembo Calipers and we have had to service the dust boots a few times, and its not cheap!
-Rafi
The Following User Says Thank You to Rafi@RR-racing For This Useful Post:
cslntuee (06-24-2015)
Old 06-24-2015, 02:21 PM   #7
wparsons
wparsons's Avatar
How about on winter driven cars in snowy climates (Canada)? Would you recommend calipers without dust boots in the winter (with salt)?
flickr
Old 06-24-2015, 02:33 PM   #8
Rafi@RR-racing
Drives: Toyota GT86
Based on our own experience and those of others, we know of no issues with Wilwood boot-less calipers when driven on the street and even in winter/salt environments.
It is good practice to power wash your car frequently in winter, including the calipers. Also, when changing pads, clean everything very thoroughly and do not simply shove the pistons back in when they are dirty. Basic maintenance will result in years of trouble free service.
If you ever need to replace seals, we have seal replacement kits for the 6 piston calipers that run only $15 per caliper.
Found this thread on the Corvette forums that confirms our experience.
http://www.corvetteforum.com/forums/...ust-boots.html
Help with purchasing spoiler Skyphire Cosmetic Modification (Interior/Exterior/Lighting) 5 05-07-2015 10:23 PM
2013 Scion FR-S Purchasing question Tero Scion FR-S / Toyota 86 GT86 General Forum 24 05-04-2015 10:14 PM
Purchasing BRZ in So Cal Rocketman1 Southern California 17 10-22-2014 06:11 PM
Purchasing FRS/BRZ liquidimports Scion FR-S / Toyota 86 GT86 General Forum 10 08-30-2013 03:29 PM
Purchasing new car soon sabre39j Scion FR-S / Toyota 86 GT86 General Forum 4 06-30-2012 12:26 AM
