Old 06-19-2015, 02:16 PM   #1
megamarines
megamarines's Avatar
Drives: 2015 FR-S RS 1.0
Send a message via AIM to megamarines
TRD Quickshifter Problems
Hey guys, so I have a dealer installed TRD Quickshifter. It's been fine up until last night. Immediately noticed lots of play and rattle, and even play while in gear. Within minutes of it happening I suddenly lost ability to shift into 1st or 2nd; and could only shift into them from a stationary position after forcing into the reverse gear and gently out.
Something definitely feels loose and the transmission has had no other issues. I'm assuming it's a loose bolt or pin, but it's incredibly frustrating to deal with. Any ideas before I pop it open or take it to the dealership?
megamarines is offline   Reply With Quote
Old 06-19-2015, 02:22 PM   #2
jaf89f
jaf89f's Avatar
Drives: Raven MT
Did you use loctite on the adapter bolt?? If not, it probably came loose (i.e. not seated correctly, not tightened enough, etc.). Seems to be a common issue, but not to what you are describing, just becoming sloppier over time. I had to tighten my adapter bolt again after the initial install once I had put some use into the part.
OpenFlash Tablet Tune v2.06 E85 Stage 1 - Grimmspeed Intake, Strut Tower Brace & Master Cylinder Brace - MTEC Clutch & Shifter Springs - TRD Quickshifter - cQuartz Finest Paint Protection Coating - and more to come...
jaf89f is offline   Reply With Quote
Old 06-19-2015, 03:25 PM   #3
megamarines
Definitely did not use loctite since it was installed when I picked it up. I'll be sure to tighten it and do that anyway.
Old 06-19-2015, 03:32 PM   #4
jaf89f
jaf89f's Avatar
Drives: Raven MT
Sorry, I missed the part about having the shifter dealer installed. If you're uncomfortable investigating yourself, take it back to the dealer stat and let them deal with it.
Old 06-20-2015, 04:43 AM   #5
megamarines
Ended up taking it to the dealer since it's covered by warranty. I have the ability to fix it but I'd rather have the installer fix it themselves.
Old 06-21-2015, 05:52 AM   #6
Freedom
Freedom's Avatar
Drives: PEARL WHITE GT86 TRD
So was it the adapter bolt that came loose in the end?
Freedom is offline   Reply With Quote
Old 06-21-2015, 06:12 AM   #7
megamarines
No idea. They haphazardly "fixed" the problem and it's still loose as hell. Basically got the run around and they tried to blame my weighted shift knob. I have to go back in on Monday for them to fully fix it. Absolutely mad as can be as to how badly they handled such a simple process.
Old 06-21-2015, 06:22 AM   #8
Freedom
Freedom's Avatar
I have the TRD quickshifter, its a very simple mod. The only thing that can go wrong is if one of the bolts come loose. There is no harm checking yourself if you have the means to do so.
Old 06-21-2015, 12:06 PM   #9
Createddeleted
Drives: 2014 BRZ - 2004 GLI
As I reported in another thread, for some installations the head of the shift linkage can cause the bolt to roll out of place; even with loctite. This binding motion from head to bolt causes the backing out and eventually failure. The last one I worked on needed some "clearancing" so there wouldn't be an issue going through the gears. 1st and 2nd usually are the culprits for the binding angle.
Createddeleted is offline   Reply With Quote
WTB TDR QUICKSHIFTER NJUL9925 Want-To-Buy Requests 4 11-26-2014 12:24 PM
FS: trd quickshifter nguyen_er Transmission and Driveline 9 06-26-2014 12:33 PM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 04:01 PM
TRD quickshifter - still notchy? unsurety Engine, Exhaust, Transmission 2 03-24-2014 12:00 AM
TRD Quickshifter lovebeingbleu98 Brakes, Suspension, Chassis 3 02-13-2014 12:14 AM
