Old 08-13-2014, 11:27 AM   #1
exam2300
Header Question
Question: Installing new headers without a tune, is it a worthless exercise, other than just for sound?
test23
exam2300 is offline   Reply With Quote
Old 08-13-2014, 11:29 AM   #2
lucid215
you will get power from it but will benefit more with a tune. also you will get a code if you go catless
lucid215 is offline   Reply With Quote
Old 08-13-2014, 11:51 AM   #3
exam2300
Will that code be a CEL?
Old 08-13-2014, 01:25 PM   #4
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Yes
Freeman is offline   Reply With Quote
Old 08-13-2014, 03:03 PM   #5
football751
Drives: n/a
IMO I'd get a tune first, such as the OFT (openflash tablet), then get a header later on. That's the route I'm going, just ordered my OFT yesterday. If you're just interested in sound you might consider a catback exhaust. This will give you more sound, doesn't benefit as much (if at all) from a tune, and won't throw any codes without a tune.
football751 is offline   Reply With Quote
Old 08-13-2014, 04:07 PM   #6
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Look at this thread: http://www.ft86club.com/forums/showthread.php?t=71412
Old 08-13-2014, 07:03 PM   #7
steve99
test23
Headers especially catless header will be an improvement
catless headers will generally cause cel code P0420 cat effieiency
you can use an 02 spacer or de-fouler fitting on the second 02 sensor to stop the cel code, about 90% sucess rate
always use new gaskets or it will leak a week or so later
aftermarket headers will put you engine warantee under a question mark and they are very obvious to service personel
headers without tune is unlikely to cause any issues cother than cel code however you will get much more benifit from them if you tune for them
headers no tune , better midrange maybe 8 wheel hp top end
headers with tune much better midrange eliminate torque dip maybe 15 wheel hp increase top end
tune will also disable the P0420 cel code so you will not need O2 spacer/de-fouler fitting on second 02 sensor
headers will increase exhaust volume especially catless
their are two cats one in headers and second one in midpipe
Header/non res catback question Pryz228 Engine, Exhaust, Transmission 0 08-09-2014 12:40 PM
Reducing the dip: Header without remap question Trettiosjuan Engine, Exhaust, Transmission 34 04-11-2014 04:02 PM
Header wrap question Gt86_nick Engine, Exhaust, Transmission 5 04-09-2014 09:58 PM
Header question ft86me Engine, Exhaust, Transmission 18 03-13-2013 11:38 PM
Stock Header Question wootwoot Engine, Exhaust, Transmission 12 12-24-2012 05:24 PM
