Old 06-16-2015, 04:15 PM   #1
nelsonzep
Drives: 2013 Scion FRS
Scion Frs Gear engagement
In the scion frs i know you can see the gear engagement right above the odometer but mine no longer displayes since i have disconnected the battery to mess with the radio just was looking didnt re wire or change anything but i was wondering why it is no longer working?
nelsonzep is offline   Reply With Quote
Old 06-16-2015, 04:22 PM   #2
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
If you read either the manual or grip of threads on this forum, you'll find its a feature that can easily be turned on or off. If it isn't back on by default after the reset from disonnecting the battery, turn ecu on while parked and change the settings.
Toyarzee is offline   Reply With Quote
Old 06-16-2015, 04:22 PM   #3
swarb
http://www.ft86club.com/forums/showthread.php?t=9446
Old 06-16-2015, 04:28 PM   #4
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
if you do a really cool burnout on video and post it here you can see the gears again
The Following 2 Users Say Thank You to continuecrushing For This Useful Post:
KellieRahne (06-17-2015), roddy (06-16-2015)
Old 06-17-2015, 11:08 PM   #5
humfrz
If you have a MT and need a light on the dash to see what gear you are in ..... maybe you should have gotten an AT ......
(jest ah messen wich ya ...... coming from the old man with a MT, who sometimes tries to take off in 3rd gear ..... )
Nope, my FR-S don't like that .... bucks a lot ....
humfrz
Jrryjms07 (06-18-2015)
clutch Engagement Issue? Bu-Tang Issues | Warranty | Recalls / TSB 68 02-19-2017 02:03 PM
Jerky clutch engagement Namuna Engine, Exhaust, Transmission 11 03-14-2014 05:21 PM
Engagement Ring Hix Miscellaneous 7 03-07-2013 02:28 PM
Engagement... so expensive. merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 43 08-02-2012 09:55 PM
1st86 Featured in Scion's latest Gear Up email Dadhawk Scion FR-S / Toyota 86 GT86 General Forum 5 05-04-2012 09:45 PM
