Old 06-15-2015, 03:45 PM   #1
86Tony
Drives: 2015 AOZORA EDITION
brakes question
Hey guys I have a 6 pot endless BBK from my lexus is350 just wondering do you think I can get it to work on my 86. Like custom brackets etc.. really want to use them instead just selling them
86Tony is offline   Reply With Quote
Old 06-15-2015, 03:56 PM   #2
swarb
yes. not sure what wheels would fit though.
Old 06-15-2015, 04:22 PM   #3
wparsons
wparsons's Avatar
And if the piston area would be anywhere close to maintain some semblance of stock balance.
flickr
Old 06-15-2015, 08:55 PM   #4
86Tony
Hmm if it will work what do you guys think I would need to get it fitted?
Old 06-15-2015, 10:25 PM   #5
swarb
custom brackets as you mentioned.
Old 06-15-2015, 10:26 PM   #6
cjd
cjd's Avatar
Drives: 2017 BRZ
Have you asked Endless?
The thought of the internet trying to walk someone through a custom brake caliper fitment scares me to no end. In the end you're probably better off financially buying a kit made for this car regardless... Not to mention guaranteed results. Even the AP kits sharing a caliper are cheaper to sell/buy vs changing out the different parts.
C
The Following 6 Users Say Thank You to cjd For This Useful Post:
8R6 (06-16-2015), AZP Installs (06-19-2015), Calum (06-21-2015), Captain Snooze (06-16-2015), fika84 (06-16-2015), wparsons (06-16-2015)
Old 06-15-2015, 11:13 PM   #7
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
C
This.
Sleepless is offline   Reply With Quote
Old 06-15-2015, 11:58 PM   #8
86Tony
C
Yes that's true but spending another 4k on endless brakes is out of the question right now. I have a baby coming September so all my money goin to her. I just have them endless brakes just sitting here bagging to be used so I guess asking endless them self is worth a try.
Old 06-16-2015, 12:03 AM   #9
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
So don't kill yourself before she is born with a shoddy brake setup.
The Following User Says Thank You to boredom.is.me For This Useful Post:
Old 06-16-2015, 11:39 AM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
My car:
http://www.ft86club.com/forums/showthread.php?t=49454
I only ended up using these because the 2002 WRX and the BRZ share same front caliper/pad sizes when I use other aftermarket big brake kits as a reference. The big thing for me was I had to flip the caliper upside down, but it was only possible because the bleeder and fluid transfer lines use the same thread pitch on the caliper.
In your case, unless the IS350 had the same size stock front calipers and the brake bias was the same as what is found on our car, I'd advise against just using "custom brackets". Don't forget the PCD is completely different as well.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
Old 06-16-2015, 12:20 PM   #11
8R6
8R6's Avatar
Drives: FRS
why not just sell that to another IS owner and then buy yourself an FRS/BRZ-specific set?
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
Old 06-16-2015, 12:43 PM   #12
mav1178
mav1178's Avatar
Probably because Endless BBK is like almost $4k for the fronts only and OP wants to be cheap.
-alex
Old 06-16-2015, 01:12 PM   #13
churchx
churchx's Avatar
Drives: 2014 GT86
Most other native BBKs are way cheaper though. And they will certainly be upgrade, unlike something blindly assembled with risks from part bins. Brakes are certainly not something i'd be willing to play with luck, even in very worst and slowest consumer blandmobiles.
churchx is online now   Reply With Quote
Old 06-16-2015, 01:59 PM   #14
strat61caster
strat61caster's Avatar
Wait, what's the point of installing this again? Looks?
ineedyourdiddly
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 05:53 PM
Brakes for looks mostly ofuts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 11-25-2014 04:52 PM
GT to GTS brakes? Turdinator AUSTRALIA 30 01-12-2014 12:33 AM
Will EVO 9 brakes fit? mike the snake Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 01-07-2014 05:13 AM
OEM Brakes? marinjim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-20-2012 10:26 PM
