Drives: 2015 AOZORA EDITION
brakes question
Hey guys I have a 6 pot endless BBK from my lexus is350 just wondering do you think I can get it to work on my 86. Like custom brackets etc.. really want to use them instead just selling them
#2 |
yes. not sure what wheels would fit though.
#3 |
And if the piston area would be anywhere close to maintain some semblance of stock balance.
#4 |
Hmm if it will work what do you guys think I would need to get it fitted?
#5 |
custom brackets as you mentioned.
#6 |
Drives: 2017 BRZ
Have you asked Endless?
The thought of the internet trying to walk someone through a custom brake caliper fitment scares me to no end. In the end you're probably better off financially buying a kit made for this car regardless... Not to mention guaranteed results. Even the AP kits sharing a caliper are cheaper to sell/buy vs changing out the different parts. C |
| The Following 6 Users Say Thank You to cjd For This Useful Post: | 8R6 (06-16-2015), AZP Installs (06-19-2015), Calum (06-21-2015), Captain Snooze (06-16-2015), fika84 (06-16-2015), wparsons (06-16-2015) |
#7 | |
Drives: 2014 BRZ
#8 | |
#9 | |
Custom User Title
Drives: Asphalt FR-S MT
| The Following User Says Thank You to boredom.is.me For This Useful Post: | wparsons (06-16-2015) |
#10 |
Drives: 2005 Toyota Camry
My car:
http://www.ft86club.com/forums/showthread.php?t=49454 I only ended up using these because the 2002 WRX and the BRZ share same front caliper/pad sizes when I use other aftermarket big brake kits as a reference. The big thing for me was I had to flip the caliper upside down, but it was only possible because the bleeder and fluid transfer lines use the same thread pitch on the caliper. In your case, unless the IS350 had the same size stock front calipers and the brake bias was the same as what is found on our car, I'd advise against just using "custom brackets". Don't forget the PCD is completely different as well. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | wparsons (06-16-2015) |
#11 |
Drives: FRS
why not just sell that to another IS owner and then buy yourself an FRS/BRZ-specific set?
| The Following User Says Thank You to 8R6 For This Useful Post: | wparsons (06-16-2015) |
#12 |
#13 |
Drives: 2014 GT86
Most other native BBKs are way cheaper though. And they will certainly be upgrade, unlike something blindly assembled with risks from part bins. Brakes are certainly not something i'd be willing to play with luck, even in very worst and slowest consumer blandmobiles.
#14 |
Drives: '13 FRS - STX
Wait, what's the point of installing this again? Looks?
| The Following User Says Thank You to strat61caster For This Useful Post: | wparsons (06-16-2015) |
| Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 119 | 12-17-2017 05:53 PM |
| Brakes for looks mostly | ofuts | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 11-25-2014 04:52 PM |
| GT to GTS brakes? | Turdinator | AUSTRALIA | 30 | 01-12-2014 12:33 AM |
| Will EVO 9 brakes fit? | mike the snake | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 01-07-2014 05:13 AM |
| OEM Brakes? | marinjim | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 08-20-2012 10:26 PM |
