Old 06-13-2015, 01:06 PM   #1
EquiFox
Drives: 2014 FRS Firestorm
Lack of power, can't figure out why (Supercharged, EcuTek)
So yeah the car started doing this a few weeks ago.
I could feel that it had a tiny bit less of power, I thought it could be caused by the gas I used at that time but no.
Now the car just feel like stock... Between 1500-2000 to 4000 approx RPM it doesnt do shit. I have 286 whp (well had) and I know something is going wrong. Before you ask, I use Shell VPower (91) gas, since its the highest we have here.
I don't know a lot, so maybe someone could help me out and chime in.
At first I thought it could be related to my Borla UEL (Had a lot of issues with those), so I switched to JDL and same thing. Atleast I got better headers now.
Also, I noticed that I have a lot of black residue on my exhaust tips now, I never had anything like that before. I cleaned it and it came back pretty quick.
Here is a log from yesterday (Standard city / highway driving)
http://www.datazap.me/u/equifox/longer-run?log=0
Thanks all !
EquiFox is offline   Reply With Quote
Old 06-13-2015, 02:23 PM   #2
Fastbrew
Drives: 2014 Pearl White BRZ
Check to see if your intake hose is clamped down tight and everything else in the intake path. Check for leaks with a smoke test everywhere.
Also - there is some rubber hosing around the purge solenoid valve that might be loose.
Just a couple of ideas of easy to check ideas - good luck.
Fastbrew is offline   Reply With Quote
Old 06-13-2015, 03:57 PM   #3
ryoma
ryoma's Avatar
how much boost are you running with the SC? you might have a leak somewhere like the person above said
Old 06-13-2015, 07:45 PM   #4
EquiFox
Im using the low boost pulley so around 9-10 psi I would say.
Old 06-13-2015, 07:56 PM   #5
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
So you don't have a boost gauge? So that means you really have no idea what the SC is putting out.
Based on the sxs you describe, I would guess your sc is not actually pumping.
billwot is offline   Reply With Quote
Old 06-13-2015, 08:25 PM   #6
Vroomin86
Drives: 2015 Fire
yea ......................................... a boost gauge would help.
2015 FireStorm FRS
HT Auto / TRD / Toms / FA 500 / Valenti / SPC / OFT / Borla / Flossy / Vigilant Motorsports / To be continued...
Vroomin86 is offline   Reply With Quote
Old 06-13-2015, 08:34 PM   #7
Bigmaxy
Drives: Pegasus GTS86
Looking at your chart. You are not making any boost.
And you are getting some knock correction.
Bigmaxy is offline   Reply With Quote
Old 06-13-2015, 09:48 PM   #8
Jcl
Drives: 2014 BRZ
Boost leak anywhere? When I first had my kit installed the clamps werent all tight and you could feel the difference right away.
Jcl is offline   Reply With Quote
Lack of tuning data due to ECUtek? 350matt Software Tuning 37 12-08-2013 12:19 AM
Moar power with simple bolt-ons & ECUTek tune @ OnPoint Dyno l8apexr CANADA 23 04-25-2013 06:50 AM
Go figure! Pdxc43 Northwest 3 01-26-2013 09:03 PM
BRZ vs WRX Skid Pad Figure 8 ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 1 05-29-2012 12:50 PM
