Old 06-13-2015, 04:39 AM   #1
Panman
Panman's Avatar
Drives: 86 GTS
Willwood Calipers to fit standard rotors?
Here's a question for the experts, what model Willwood calipers would fit our standard rotors?
Looking for either 6 or 4 piston options...
Panman is offline   Reply With Quote
Old 06-13-2015, 07:13 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
I'm not sure it's worth to find ones that just 'fits' in sense that they can be mounted in right position, and ignoring what may happen to brake bias by mounting some random calipers on stock disks. Yes, you may save some cache by not purchasing full BBK kit, and yes, you have 90% chance of making braking worse/less reliable then stock, not improve it.
Old 06-13-2015, 07:38 AM   #3
Panman
Panman's Avatar
Drives: 86 GTS
Thanks for that, but that wasn't my question
Old 06-13-2015, 09:51 AM   #4
Cuchullain
Cuchullain's Avatar
Drives: 2013 GBS Subaru BRZ Limited
What is your goal? There are different answers for different goals. Is this for looks? Save on consumables with a different pad shape / size? Wilwoods website is pretty good at helping you find what you are looking for as well. You can sort calipers by size, mounting type, material, etc.
If you just want a fixed caliper versus a floating caliper for looks or maybe marginal feel, I would just go with the FHI 4/2 pots. Probably your cheapest option and the bolt right on the front, and there's an adapter for the rear. Wilwood doesn't sell the adapters for their calipers separate from kits as far as I can tell.
Cuchullain is offline   Reply With Quote
Old 06-14-2015, 03:39 AM   #5
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
FHI 4/2 setup isnt stock brake bias. Using Z32 calipers with LGT rotors does though. And they sell brakets for them as well.
CxG (06-03-2016)
Old 06-14-2015, 04:29 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
Z32 calipers, brackets for them, LGT rotors? Add to that cost of steel brake lines.. It somehow seems that needed list of parts widens and summed price won't be THAT much cheaper (if savings is main intention) from normal full kit designed especially for twins. Not sure it's very wise to try out luck with assembling from part bin for something as important as brakes and bet one's safety on that. I wouldn't call that as .. "upgrade".
Old 06-14-2015, 05:08 AM   #7
finch1750
finch1750's Avatar
I never said it was an upgrade, just thats its better than the FHI setup as brake bias doesnt get jacked with. If he is looking for aesthitics only its cheaper and safer than some other options. Full setup front and rear should be under a grand minus pads.
But for OP just figure out what size pistons you need to keep stock balance and call Willwood. Its simple enough to figure out with online calculators.
Old 06-19-2015, 07:35 AM   #8
makinen
makinen's Avatar
Drives: Toyota 86
Hi,
This http://www.ft86club.com/forums/showthread.php?t=76939 could be a starting point.
makinen is offline   Reply With Quote
Old 06-19-2015, 01:36 PM   #9
BunnyRZed
BunnyRZed's Avatar
Drives: BRZ Limited [37J]
Just go Subaru 4/2 pot, legacy GT 2 pot or STi Brembo.
BunnyRZed is offline   Reply With Quote
Old 06-19-2015, 02:11 PM   #10
OkieSnuffBox
Drives: '23 BRZ Limited
Closest would be the Dynapro's used in this kit:
http://www.ft86speedfactory.com/wilw...black-830.html
But those are designed for a rotor with a larger diameter and less thickness. Of course then you'll likely need a custom made bracket to properly center the rotor horizontally and radially over the rotor.
Or you could just spend $1000 on the kit I linked and pull 32lbs out of the front of your car.
Old 06-21-2015, 08:12 AM   #11
Rafi@RR-racing
Rafi@RR-racing's Avatar
Drives: Toyota GT86
If I may suggest our Stage I or Stage II kits. They are very economical, use 13" solid high carbon premium rotors and 6 pot Wilwood Forged Superlite radial mount calipers (which are race worthy calipers, unlike Dynapro's). Best of all, if you go with a Stage I or II, and you want to take it to the next level, you can always upgrade to our Competition 2-piece floating rotors without scrapping the BBK you already bought.
-Rafi
Rafi@RR-racing is offline   Reply With Quote
The Following User Says Thank You to Rafi@RR-racing For This Useful Post:
Panman (06-21-2015)
Old 06-22-2015, 01:16 AM   #12
86drift
86drift's Avatar
Drives: Toyota 86 GT
These:
http://www.wilwood.com/Calipers/Cali...temno=120-9702
But they move the bias rearwards. Which is a good thing in my case.
86drift is offline   Reply With Quote
2013 STi Brembo calipers, pads and rotors The Racers Line Brakes, Suspension, Chassis 9 05-29-2015 02:24 PM
FRS/BRZ Affordable OEM Caliper BBK - Larger Rotors with Stock Calipers! RB Performance Brakes Brakes, Suspension, Chassis 60 08-11-2014 02:01 PM
Aftermarket Calipers and Stock Rotors Anorexic 86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 12-27-2013 01:08 AM
OEM Calipers, brakes and rotors. 800 miles driven RUNAMUK Brakes, Suspension, Chassis 3 05-24-2013 04:04 AM
