Old 06-07-2015, 09:23 PM   #1
Clint_1111
Clint_1111's Avatar
Drives: 2013 Asphalt FRS/2007' STI
So how do you fix this? SPC LCA with Stance coilovers
So I had initially installed the SPC rear LCA and Stance coilovers with success. I went to adjust the ride height in the rear and started to unbolt the hub, sway bar and strut. Adjusted the rear ride height to where I wanted it and now I can't get the rear LCA to line up to the Hub at all. Spent a few hours trying different combinations on getting it aligned properly and it just wasn't working out. I even took the coilover off completely to see if that what was causing the issue and I couldn't get the LCA to line up. Any help or ideas appreciated. I'm hoping it's something simple I'm overlooking. Thanks.
Clint_1111 is offline   Reply With Quote
Old 06-07-2015, 09:50 PM   #2
Spinning Sushi
Legend
Spinning Sushi's Avatar
Drives: BRZ Limited
This happened to me after I installed my Cusco LCA's. I used a pry bar and a jack to help move it around. I had to pry and pull pretty hard then I bolted up the hub. I then jacked up the hub some more to get the coilover in.
Spinning Sushi is offline   Reply With Quote
Old 06-07-2015, 11:35 PM   #3
Vroomin86
Drives: 2015 Fire
Jack up the arm. Use a thick screwdriver and put it through. Make sure you use a piece of wood so you don't damage the arm.
2015 FireStorm FRS
HT Auto / TRD / Toms / FA 500 / Valenti / SPC / OFT / Borla / Flossy / Vigilant Motorsports / To be continued...
Vroomin86 is offline   Reply With Quote
coilovers, issues, lca, spc, stance coilovers
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 08:56 PM
FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers ill roller Brakes, Suspension, Chassis 5 12-14-2013 03:02 PM
