Old 01-24-2012, 11:30 AM   #1
nrclptcnsmniak
Professional Athlete
Drives: Marty's Hover Board
Open Deck Block
It has just been released that the frs/brz will have an open deck block. How does this change your plans for modifications? How does it change the expected HP gains from bolt ons? And please explain in layman terms :happy0180:. The reason for this thread is I have seen people state they need to change their plans a bit now that this has been released.
edit: dont spam "i dont care" if you simply dont care then please dont post. I would like info regarding this not because I am concerned about HP gains (because I am keeping my car stock) but more out of curiosity from the minds of those whom planned to do some mods to their car (seriously expensive or relatively inexpensive). I am not a tuner so I would like to hear from them. Just for my own curiosity and my desire to gain knowledge. Its a discussion and not one to be had with people stating 'I dont give a F*&#" because that doesnt benefit me or the readers. THANKS ^_^
I'm the type of guy who loves his girlfriend.
nrclptcnsmniak is offline   Reply With Quote
Old 01-24-2012, 11:59 AM   #2
ubersoph
I'm autocrossing, not a fuck is given.
ubersoph is offline   Reply With Quote
Old 01-24-2012, 12:04 PM   #3
Syldrin
Troll Feeder
Syldrin's Avatar
Drives: boosted scion tc.
the 2AZ-FE is open deck and i have seen big power made and have pushed 400 myself on a stock block so really i could care less. plus if there are problems ERL and Darton will release sleeves in a matter of time.
Syldrin is offline   Reply With Quote
Old 01-24-2012, 12:10 PM   #4
nrclptcnsmniak
^ I dont think you can compare a boxer four to an inline 4 in terms of hp gain. can you? I see that the bore n stroke are the same though. How about somebody explain the difference between open deck blocked or semi open? or closed? not too sure.
Old 01-24-2012, 12:15 PM   #5
Bob
Hattori Hanzo's steel
Bob's Avatar
Drives: Audi B5 A4 1.8TQM, Kia Forte 5dr
^^^ SAME.
Do you know what SCCA stock class we will fall into? S2Ks run BS, but Miatas with 1.8L run CS... i haz a confuzion
Bob is offline   Reply With Quote
Old 01-24-2012, 12:17 PM   #6
nrclptcnsmniak
Originally Posted by Bob View Post
^^^ SAME.
ok dont thread jack thanks.
Old 01-24-2012, 12:27 PM   #7
Bob
Bob's Avatar
I believe open deck vs closed deck refers to the block. If you look at the top (or side, in this case) of the bare block, looking down the cylinders, the area around the cylinders will be "hollow" or open. This could potentially cause an issue if you run crazy high boost pressures, there is a lack of reinforcement that a "closed" deck might offer. The thing that slightly concerns me is heat dissipation... so many miles and heat cycles, I wonder how round they remain over the years.
Maybe someone else could chime in? I think Im on the right track, but not sure.
/unintentional thread jack
Old 01-24-2012, 12:46 PM   #8
madfast
Drives: 2010 Evo X MR-T
open deck is fine. i believe GM tested their stock ecotec block for import drag racing and failures only occurred after 500+ hp or something like that.
madfast is offline   Reply With Quote
Old 01-24-2012, 01:07 PM   #9
Dimman
Kuruma Otaku
Dimman's Avatar
As above. Open deck only becomes an issue with big cylinder pressures. And there will be plenty of aftermarket solutions for people chasing those big pressure/power numbers. There are tons of big power modified open deck motors out there.
Because titanium.
Old 01-24-2012, 01:50 PM   #10
mastawyrm
Drives: '10 Mini ClubmanS '95 Z28 08 VW GLI
This seems pretty relevant
http://legacycentral.org/library/literature/deck.htm
mastawyrm is offline   Reply With Quote
Old 01-24-2012, 01:55 PM   #11
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
pistons exert force on the sidewalls of your cylinders as they travel up and down (or left and right in our case)
if this force is great enough, then the cylinders begin to deform/warp/move
as a visual example, take an empty toilet paper roll and hold it up in the air and put your finger inside and move it up and down along the wall without applying too much pressure.
nothign right?
now apply lots of pressure and see your cylinder turn into an oval.
this is not good, because now your pistons are not sealing, pressure is lost, oil gets into places where it's not supposed to, all a big mess, next thing you know and BOOOM
a closed deck is just a cylinder designed with reinforcements... which are only necessary if the cylinder is weak to begin with
if your toilet paper roll was made out of solid steel, no amount of pressure from your finger would deform it!
however much the stock FT86 engine will hold will be determined once it's out.
Old 01-24-2012, 01:57 PM   #12
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
This is going to end up being a non-issue for the vast majority of owners.
I'll hazard a guess that most owners will limit their engine modifications to "bolt-ons" like intake, header, exhaust, and ECU tune. Open deck isn't going to make a bit of difference for them.
Even aftermarket bolt-on turbo/supercharger kits won't be bothered with the open deck as the static CR will likely be the limiting factor.
The only people that will likely ever care or notice the open deck are those pushing double-ish stock HP level.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 01-24-2012, 02:31 PM   #13
Longhorn248
Hook 'em
Longhorn248's Avatar
At which point you would consider sleeving the cylinders anyways correct?
Longhorn248 is offline   Reply With Quote
Old 01-24-2012, 02:44 PM   #14
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i'd put in a different engine all together...
you have to define what you want to do,
do you want to make a point and build up X engine to make Y power
or do you just need Y power and don't want to worry about anything else?
drop in a straight 6 from a supra or something and call it a day.
GReddy in on-deck circle. GReddy turbo for FR-S/BRZ first up. 2JZ-DNA Engine, Exhaust, Transmission 46 04-19-2012 08:13 PM
Open Air FR-S Concept Rampant FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 22 02-01-2012 11:01 PM
Keep your eyes/cameras open in SoCal? Buggy51 Scion FR-S / Toyota 86 GT86 General Forum 14 10-10-2011 10:21 PM
Ken Block Gymkhana 3 Midship Runabout Other Vehicles & General Automotive Discussions 24 09-14-2010 11:55 PM
