Old 06-02-2015, 05:33 PM   #1
Andrew_FRS_DD
Drives: 2013 Whiteout Scion FR-S
Rims first or coilovers first?
so i was wondering if i should get coilovers first or the rims and tires first? or does it matter?
Andrew_FRS_DD is offline   Reply With Quote
Old 06-02-2015, 05:38 PM   #2
HATED1
HATED1's Avatar
Drives: 86
If you can get both at the same time it would be best so you only have to do the alignment once. However, I have always done coils and Rear Lower Control Arms first.
Having nice rims without the proper stance/set-up is one of my pet-peeves, but that's just me.
HATED1 is offline   Reply With Quote
The Following User Says Thank You to HATED1 For This Useful Post:
SVLTE (06-03-2015)
Old 06-02-2015, 05:44 PM   #3
ChrisV
Drives: 2014 FR-S 6MT
You don't have to align a car when you change wheels and tires. Wheels do not alter suspension settings. The hub face stays in the same location.
ChrisV is offline   Reply With Quote
The Following 2 Users Say Thank You to ChrisV For This Useful Post:
akahenry (06-25-2015), strat61caster (06-03-2015)
Old 06-02-2015, 05:47 PM   #4
8R6
8R6's Avatar
Drives: FRS
are you looking for more performance or for looks? if you're going for looks mainly though, then definitely coilovers first so you can see what drop you want and calculate the exact wheel/tire specs you want.
8R6 is offline   Reply With Quote
Old 06-02-2015, 05:49 PM   #5
86_Insider
86_Insider's Avatar
This is completely true, but typically if your tires are worn out it is a good idea to get an alignment when putting new tires on. Chances are something is slightly off from potholes or other road issues.
86_Insider is offline   Reply With Quote
Old 06-02-2015, 05:53 PM   #6
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
Lowered + stock wheels looks okay
Stock height + bigger than 17" wheels = 4x4 look
Both at the same time is best!
projek_01 is offline   Reply With Quote
Old 06-02-2015, 05:53 PM   #7
Andrew_FRS_DD
i am planning on tracking this car and also use it for daily driving and dont really care much for looks
Old 06-02-2015, 06:01 PM   #8
ChrisV
Agreed, which is why it's a reasonable recommendation to get an alignment when your tires are worn out.
Old 06-02-2015, 06:01 PM   #9
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
Coils+LCA first. Then get some grippy 225 tires on your stock wheels and you should be set.
ApolloSki is offline   Reply With Quote
Old 06-02-2015, 06:13 PM   #10
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Proper wheels and tires first and don't even bother with coilover suspension until you know that the stock suspension is holding the car back. Lightweight wheels with properly sized track oriented tires (read stock size or SLIGHTLY wider) are extremely capable on track with an otherwise 100% stock car...Plus just lightening the unsprung mass by 4-5lbs a corner with lightweight wheels and proper tires does wonders to improve the ride quality over how it feels stock.
I'd put money towards the brake system (the car's absolutely weakest link) and an oil cooler (second weakest link) before even thinking about changing the stock suspension in any way. Those are much more critical to have done if you are seeing any track use.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following 5 Users Say Thank You to Vracer111 For This Useful Post:
akahenry (06-25-2015), Captain Snooze (06-03-2015), chas3wba0 (06-02-2015), rlpaul (06-03-2015), strat61caster (06-03-2015)
Old 06-02-2015, 07:01 PM   #11
Andrew_FRS_DD
awesome
thank you guys for all your inputs
Old 06-02-2015, 07:19 PM   #12
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
doesnt matter, but both are cool to have haha
Old 06-02-2015, 07:31 PM   #13
rainmonkey
Drives: BRZ - Dark Grey
Do note that if you're going to get relatively wide wheels and/or wide tires before getting coils or springs or whatever, you just might end up not being able to fit the wheels/tires on stock suspension...
That would be fun, new shoes, but you can't wear em. If you're set on getting wheels/tires first, make damn sure they'll fit on stock suspension
rainmonkey is offline   Reply With Quote
The Following User Says Thank You to rainmonkey For This Useful Post:
juliog (06-03-2015)
Old 06-02-2015, 07:34 PM   #14
KevinK121
Miata traitor
KevinK121's Avatar
Drives: 2002 Miata SE
I'd buy the wheels and tires first as well.
My decision in that order is based on how bad I think the oem wheels are though lol
KevinK121 is offline   Reply With Quote
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
Trade: BRZ stock rims + Michelin Pilot Super Sport for stock rims & tires + $600 Ferrari Canada Classifieds 7 05-12-2015 02:45 PM
Stock rims +coilovers +spacers +LCAs ang31ito Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 04-03-2014 04:22 PM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 08:56 PM
245 or 255 bad tires + light rims = 225 mid-gripy tires + normal rims? Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-18-2013 02:33 PM
